Question about Toshiba Satellite M55-S329 Notebook
Audio speakers will not play
The AC-97 speakers will not play any sound though the device is enabled.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    have you checked to make sure they are not muted or turned down?
Ue boom connected to pc but is not playing music... if i get lucky i get muffled sounds play back, how do i fix this
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
  • Move the audio source closer - it might be out of the range of your speaker.
  • Move away from other sources of wireless signal - you could be experiencing interference.
  • Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
  • Adjust the volume on both the audio source and your speaker.
  • Restart both your speaker and the audio source.
  • Re-pair your device with your speaker (see, "How do I pair additional Bluetooth® devices with my speaker?").
  • If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
Dec 26, 2014 | Microsoft Computers & Internet
No sound but showing audio device
check your laptop for volume up/down buttons on the front
Mar 23, 2013 | Toshiba Satellite M35X-S311 Notebook
Why is there no sound coming from my laptop
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 14, 2012 | Computers & Internet
No sound on computer and comp can not play music
This issue will occur if the Computer speakers are not to the default Audio Device. Please right click on the Sound icon on the right corner of the Taskbar (System Trey) and select the "Playback Devices". After that, please right click on the "Speaker/Headphones" to set them as the default Audio Device. This should enable the Computer speaker and sound should work correctly.
If the above steps did not resolve the issue, you may need to re-install the Audio Driver in the Computer to resolve the issue. You can download the Audio Driver using the below link.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/7ka213ww.exe
Restart the Computer after re-installing the Audio Driver.
This should fix the issue with the sound.
Hope this helps..
Thanks for using Fixya.
Oct 01, 2010 | Lenovo ThinkPad T61 Notebook
Sound
inux:
1. System has been set as “Volume mute”. Please press Fn+ F7 to enable speaker.
2. Please click the Diagnostic Tool icon under the Setting Tab==>System Test==>Audio, and test it.
3. Please restore the system for a try.
4. If it is a hardware related problem, please contact the local service center.
XP:
2. Reinstall the audio driver.
3. Using the support DVD or hard disk partition (requires a recovery partition) to restore the system for a try.
Mar 28, 2010 | ASUS Eee PC 1000H Laptop
Aspire 5515 dvd wont play sound
Does the laptop play CDs?
If so then when you start a DVD and before you play the movie, go into the audio setting and configure the speakers for laptop stereo speakers.
If you cannot hear music from the CD then check :-
1. The audio settings, volume not set to minimum and mute is not ticked (enabled)
2. Device manager - sound device is enabled and working, if not re-install the sound driver.
Nov 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
No sound in media player
The best will be to start by downloading and installing the chipset drivers for your notebook, which can be downloaded from:
http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
Make sure to restart your machine after installing the chipset.
Secondly download the Audio driver(s) from:
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
Install the driver and follow instructions.
Hope that solves your problem?
May 27, 2009 | Computers & Internet
External speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
May 22, 2009 | Toshiba Satellite A75-S211 Notebook
Sound
Windows can only play sound through one device at a time unless you have multiple audio devices, (i.e. USB headphones and onboard soundcard)
Even when you have multiple audio devices, very, very few programs have the ability or need to play the same audio through 2 different devices at the same time.
you can for example though, play winamp through your speakers while playing a vido game in your USB headset. Basically it is possibly to have different audio going the different devices at the same time but it is generally not possible to have the same audio going through different devices at the same time.
Jan 19, 2009 | Dell Inspiron 1501 Notebook
HP Pavilion A1120N
Verify the sound device is enabled If there is no sound from the speakers or headset, use the Device Manager to determine the state of the sound hardware.
  1. Click Start , type manager into the search field, and select Device Manager . Alternately, click Start , Control Panel , Hardware and Sound , and then Device Manager .
  2. Double-click Sound, video and game controllers .
  3. Do the following, depending on what is seen:
    • If a sound device is listed with a down arrow , the device is disabled. Right-click the sound device name and select Enable to re-enable the device. Go to the next step if problems continue after enabling the device.
    • If a sound device is listed and enabled , right-click the device name and select Properties to view more helpful troubleshooting information in the Device Status window. If Device Status shows that the device is working properly, the problem is likely related to sound settings, the speakers, or the audio cables and connections.
Dec 25, 2007 | HP Pavilion DV4015cl Notebook
Toshiba Satellite M55-S329 Notebook Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
