How do I play and/or connect to my iTunes from and external drive
If I have all my iTunes music downloaded to my laptop it takes up a large amount of disk space and slows my computer if possible I would like to play this music from an external drive and have not been able to figure out how to do this. I hope there is a simple fix.
  • 2 more comments
  • Leslie D. Wilson
    Leslie D. Wilson Nov 16, 2008
    My first problem is how do I create the directory on the external hard drive that this is where I want iTunes to store the music? This is where I'm having the problem. Thanks for your help.
    Les
  • Leslie D. Wilson
    Leslie D. Wilson Nov 17, 2008
    I went all the way back to square one, I thought I had it solved. I downloaded iTunes a new copy, copied all my music to it, mapped the external hard drive, changed the drive set up, transferred my music to the new folder in the external drive, opened iTunes confirmed the music was there, checked the drive path everything looked good. Deleted the iTunes folder on my laptop drive, opened iTunes again and that's where the problem again occurred that is no music. Any ideas, again thanks for the help.
  • Leslie D. Wilson
    Leslie D. Wilson Nov 22, 2008
    I did everything again and went to "Add folder to Library" this option doubled everything in my library. Okay I figured I would delete the library on my laptop and be back to only one copy of my library, wrong again when I went to open iTune I had no library whatsoever. Maybe there isn't a solution to my problem but I do thank you for your help and advise.
  • Leslie D. Wilson
    Sergeant:
  • 207 Answers
LeftField,
Attach your external drive.
Create the directory on that drive that you want Itunes to store your music.
Open up Itunes.... go to the edit menu and select preferences.
Go to the advanced tab. there is an option there for change my preferred directory. Change this to the directory you created at the beginning of this instruction.
Now copy all of you songs from your music folder on the laptop to the one on the external drive.
Confirm that ALL of your songs transferred OK then delete them from the laptop.
You should NOW be all set to enjoy music from your external drive. (Be sure to always have your external drive attached when you open Itunes.... If yoou don't Itunes will look for the external, not find it and revert BACK to the default directory)
Hope this helps you
Dave
Posted on Nov 16, 2008
  • David Preston
    David Preston Nov 16, 2008
    Les,
    [These Directions are for Windows if you have a Mac then I have to do some research before answering]
    First we need to determine if your external dive is formatted.
    When you plug it in, after it loads any needed drivers, do you see a new drive letter in "My computer"?
    If so the Drive IS formatted and ready to go (Proceed to step 1)
    If not comment back and I will instruct you how to format it.
    1.) open "My computer"
    2.) Double click the drive that represents your external drive (Probably D:\) but may be different depending on YOUR particular drive configuration
    3.) Unless you've saved something to this drive before you may be looking at an explorer window that is empty or may be looking ate some files and /or folderrs in the window
    Right click any empty space in the Window and select "New" from the drop down list and then Folder and left click.
    4.) this should put a new folder in the Window with a blinking cursor below. Type in a name meaningful to you such as "Itunes" or "Itunes music" or anything else you choose to call it.
    press Enter
    You now have a suitable directory for your needs.
    Hope this helps you
    Dave
  • David Preston
    David Preston Nov 17, 2008
    Les,
    Sorry I forgot One kinda major step.
    We told Itunes that your new folder is WHERE you want newly downloaded songs stored to. However I forgot to have you tell it that THATS where it can find current music.
    OK so here is how we do that. Open up Itunes and click on file. A drop down list opens up and from that list you can select "Add folder to the library" select the one you created on the external drive and click OK. Once you do this it will scan all your music and add them to your library with its proper address.
    Sorry for the confusion
    Take care
    Dave
How do I transfer my music library to a new computer using the simpletech 1tb simpledrive?
itunes requires that you authenticate a computer with your log in account simply log in with old computer, save the itunes library to ext drive
then de authenticate the old computer
log in with new computer and authenticate it
then bring the itunes files on to new machine
takes a while but it works
Jun 14, 2012 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
Tip
Make a back up of your music on an external Hard Drive or Flash Drive
Copy iTunes folder to your external hard drive
To copy all the items in your iTunes library (including the iTunes Library file that holds all your playlists, playcounts, ratings, and other data) to your external hard drive, follow these steps:
Quit iTunes.
Locate your external hard drive.
Mac: On the desktop or Finder sidebar.
Windows: In My Computer
Locate your iTunes folder:
By default, the iTunes folder is located in:
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions:
Open your iTunes Preferences:
Mac: Choose iTunes > Preferences.
Windows: Choose Edit > Preferences.
Click Advanced.
The location of your iTunes folder will be listed in iTunes Media folder location box, as pictured below.
Drag the iTunes folder to your external hard drive. This can take a while if you have a lot of items.
When the transfer is complete, your iTunes Library will have been successfully copied to your external hard drive.
on Apr 15, 2010 | Computers & Internet
I recently purchased a macbook pro and would like to transfer my music from my pc to my mac. I have downloaded itunes 9 but can't figure out how to transfer the music from a flashdrive to itunes since...
There are several ways to do this. You can follow the instructions in the following article to back up your iTunes library on CD/DVD:
http://support.apple.com/kb/ht1382
Alternatively, you can use your iPod classic to transfer your music as per the instructions in the following article:
http://support.apple.com/kb/ht1329
You can also transfer the contents of your iTunes library via a flash drive or external drive, simply copy My Documents / iTunes to your external hard drive / flash drive, transfer it to your Mac, and then drag and drop the entire iTunes folder onto the iTunes icon in the dock and it will automatically import all of your songs, settings, and playlists.
Aug 13, 2010 | Apple MacBook Laptop Computer Mac...
Transfer macbook pro music
There are a number of different ways to do this. If you have an external hard drive, all you need to do is drag the Macintosh HD/[your user name here]/Users/Music/iTunes folder onto the external drive, connect the external drive to your Macbook, and drag and drop the iTunes folder from the external drive onto the iTunes icon in the dock. <br /><br />If you have an iPod classic, you can do this: <br /><br />http://support.apple.com/kb/ht1329<br /><br />...or if you don't have a huge library and/or have a lot of CDs/DVDs you can use, you can back up your library to disc: <br /><br />http://support.apple.com/kb/ht1382<br /><br />...or if you have anything other other sort of iPod, iPhone, or iPad, you can rip the music from it using this utility: <br /><br />http://thelittleappfactory.com/irip/<br /><br />
Aug 08, 2010 | Apple MacBook Pro Laptop Computer with...
Itunes music sounds distorted somtimes and not others
The fault is from your laptop speaker. I think it has a hole inside and maybe that's why it distorts. Or maybe the sound/volume is too loud and the speaker does not have the capacity.
I would advice you to get an external speaker for your laptop.
Take care.
Dec 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Need to download music from iphone to itunes on computer
I think it works on sharepod
getsharepod.com/download
Mar 14, 2009 | Apple iPhone 3G
IPOD how to move music
hi,
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Dec 15, 2008 | Apple iPod nano 3rd Generation
Don't know how to upload music onto LG enV VX9900 cell phone
buy a micro sd card from any electronics store, put it into your computer(card reader)move selected songs over to the card, take it out of computer and put into phone. Menu,media center, music and tones,my music
Dec 05, 2008 | LG enV VX9900 Cellular Phone
I have an Acer Aspire with two hard drives, can I move all of my music?
Its not two hardrives, its duo processor, and two cache chips
check the size of data and acer drives (right click and properties, check size)
If they are large should be able to store copy of music
go into the limewire download folder, should be in my computer -> c: -> program files -> Limewire -> shared folder - copy files (edit select all, edit copy or ctrl + left clikc to individually select)
then paste to new directory or folder (right click empty sapce of folder & left click paste
same for Itunes - locate where files are saving to then just copy paste from one location to another
should effect the programs from working, unless You delete files
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
