Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water maker issues
My water maker was running ver slow. I followed some advice and disconnected the hose at the back , reconnected and it worked fine! For about 3 days. Now it's spurting out at the beginning and then dripping through. Help!
  • 237 Answers
If the fill tube continues to drip water the fill valve is likely going bad. Is there a water filter in the system that you can check? Did you flush the main line in the back into a pan for a few seconds while you had it off to check flow rate, etc.?
Posted on Nov 27, 2006
My Refrigerator has not made ice since house water was turned off for 3 hours and turned back on, how can i fix?
disconnect (or turn off) the freezer; also disconnect water supply. Keep that for a day to unfreeze water pipes inside then reconnect.
Mar 30, 2015 | Refrigerators
I have a Jenn-air JSD2789GEQ the ice maker was working but now has quit , the water is working but slow and not much preasure
Most likely your inlet valve is bad. To test this disconnect the hoses from the inlet valce. One line is from your home the other two are the ones you disconnect. Test the door water first. After that switch the quick connects that run to the inlet UNPLUG fridge first. Switch connections plug back in and than test water in door again. See how much water is coming out. If plenty of water than in may be in your reservoir or your filter. If low pressure disconnect water line from home and see if you have good pressure If you have good pressure from the house than replace the inlet valve. If you dont than check house water pressure.If you have any questions please feel free to comment me.
Jul 29, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not making ice.
TRY DISCONNECTING THE ICE MAKER FROM INSIDE AND RUN HOT WATER OVER IT UN TIL IT IS COMPLETELY THAWED, THEN RECONNECT IT AND SEE IF IT WILL MAKE ICE NOW. SOMETIMES ICE MAKERS CAN BECOMED BLOCKED BY ICE.
Apr 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My washer cold water wont work the supply is good and it puts out hot water whats wrong
If I understand your issue correctly, you're saying no cold water gets to the machine. If that's true, then do the following:
Turn off the hot and cold water to the machine
Disconnect the cold water hose to the machine - catch the water from the hose in a small container
Check for a plugged water inlet screen - this is pretty common
Clean the screen, reconnect the hoses, turn on the water, check for leaks and try again
If no luck, you may have a bad cold water inlet fill valve, but it's much more likely to be a plugged screen
Mar 13, 2010 | Crosley Washing Machines
Water wont go all the way into the ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
Clogging Frequently -- Very slow brew
Hello enrichyourli,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Jun 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Some water is steaming and not going through the pot to make coffee. Coffee very slow in perculating
Hello jfortnideone,
Jun 12, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker making noise but not releasing coffee
Hello k_alderman
Mar 27, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Jul 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Water Fill Issues
try unscrewing the hose at the back of the machine. There should be another filter there. If this doesn't solve the problem replace the fill valve. This part is not expensive. Take the old one with you. a generic is much cheaper. I have bought new for under $5. You can fix this yourself.
Jun 30, 2008 | Fisher Paykel EcoSmart GWL15
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
