Question about iRiver T10 MP3 Player
My iriver T10 is not being detected
When I plug it into the usb the computer does not detect my device, on top of that the installation cd just installs windows media player, not the iriver software. The iriver screen sayas usb connect, but the computer acts like nothings is there. No errors, just nothing.
  • 11 more comments
  • Anonymous Nov 02, 2007
    yes i got the same problem. software installing don't help. driver update impossible
  • bobbby Nov 07, 2007
    My old computer worked fine with the iriver t10- however as of recently it is in the garbage and I now have a new machine- The new computer was detecting the iriver t10 but whatever action i tried to take it would not follow through on - If I tried to delete or add files it would go through with it for the the first couple files and then stall and do nothing - I have now reformatted the device in the advanced settings and the computer wont recodnize it all-
    Also i do not have the original disk that came with the player- Can anyone help ?
  • Helltyvoy Nov 07, 2007
    can i get a hardware repair of iriver t10 512mb co'z it does not detect on my pc can't also update it can u help me on this?this problem when i overload the battery causing a dead iriver plss help me... thanks
  • Anonymous Dec 06, 2007
    my iriver t10 512MB is not detected also
  • jorgemorenof Dec 20, 2007
    Frit,
    Dude how can we upgrade the firmware if our computer DOES NOT recognize the T10? Unfortunately, I have the same problem. Does anybody know how to fix it?
  • hrdnox Mar 06, 2008
    Same Problem here - only difference is, I had just gotten unit back from iRiver after repairing a problem with the unit - it wouldn't power on at all. Now that the problem is fixed and the unit seems okay - it isn't being recognized by the computer.
    When iRiver had their own software to put music on the device everything was great, then they relied on Windows Media Player to work - which it doesn't seem to.
  • Anonymous Mar 07, 2008
    Same problem here. ARRRGH!
  • ike 1 Mar 09, 2008
    This PC, and three (3) other, that I have tried to copy music form CDs to my MP3 will not allow me to do that. Media player opens up, there is an icon for iRiver but none the less, I CANNOT trasfer the songs. I/We have tried transfering from Libray with list etc. and that would not work is the reason we tried the "simple" approach of dowloading the songs to CDs, wich will play on Media Player but not "transfer", IKE.
  • Anonymous Apr 24, 2008
    I got the iriver from my friend and and he told me as far as he knew i didnt need any specific software other than windows media player to ad and remove music and when i connect the iriver to my computer the iriver says its connected but the computer dosnt register it
  • rakeshgi Jul 02, 2008
    hi this is rakesh i have a problem with my iriver T10 that windows is not recognised the USB storage device it is malfunctioned that is the message i was showing what can i do give a suggistion
  • CHCHDave Oct 24, 2008
    Have had this T10 for ages, one day I plugged it into my PC (XP HOME) and it didnt recognise, at the time I didnt have the time to sort it out.
    so I left it a week or two plugged it in again and it worked.
    however after that day... it only shows 'USB Connect' on the T10 LCD and absolutly nothing happens on the PC not even the noise that you get when ANY usb device is connected :( I won this t10 and it has been great until now... I am hoping this can be fixed.... Please Some One HELP!!!!
  • nk_howard Dec 27, 2008
    my iriver t10 will not connect to my computer
  • www_igor_buc Dec 29, 2008
    privet
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at NOHEMYGIRALDO@SBCGLOBAL.NET
Posted on Jan 15, 2008
    Scholar:
  • 67 Answers
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC. iriver only uses windows media player now. there is no iriver software anymore.
Posted on Jul 29, 2007
  • RMIR Dec 27, 2010
    Thank you! I tried the other solution from Spiky and was very disappointed when that did not work. I have a new iriver which worked the first time I uploaded music. This time I couldn't get the cmputer to recognize the device..malfunction message kept popping up. Even though I ws nervous about losing all the music by re-formatting, decided to go ahead with it. Thankfully, it has worked! Do you know if this is a permanent fix or if this could re-occur? what could be the underlying reason? will the firmware upgrade fix it for a longer term? Again, thank you for sharing this solution!!!
Install windows media 10 or 11. I prefer 10. Your computer will then "see" the T10 storage device.
Posted on Feb 23, 2009
I'm going to add something to Spiky2033, whose advice I used and helped me get what I need. I selected the "recommended option" however you are also cued to put in the CD-ROM if you have it. If you have it, then only insert the CD when cued. The Device Manager will start searching and it will begin with the CD. It found the driver on the iRiver CD. Now, to most folks (including me), the CD looks as if it only helps you download Media Player. However, to my surprise, Device Manager found the driver software.
Posted on May 13, 2008
Spiky2033's solution worked like a charm! Just make sure the device is plugged in and turned on. I did not have to put in a disk or anything.
Posted on Apr 12, 2009
  • 3 Answers
I was having the same trouble... The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Posted on Nov 27, 2008
I had this problem if you dont have a certain usb it doesnt show up
Posted on Nov 14, 2007
Ineed a usb cable for a t10 iriver mp3 player
Computer shops sell USB cables. Take your Iriver player with you to the computer shop because the USB cables come with different size connectors and you need one that fits your player.
Mar 03, 2013 | iRiver Audio Players & Recorders
I just got my Coby Mp3, and i plugged the USB into my computer and the autoplay screen that is supposed to come on my computer, hasnt.
Does you computer detect a new device when you plugged the Coby MP3 player?
If Coby MP3 player has cd driver, better to install it to your pc. Some computer/laptop doesn't detect autoplay when new USB device plug-in
May 07, 2011 | Coby MP828 MP3 Player
Computer cant find my iriver 120
if u have data cable with your device plug it into
the usb port of your pc and put the installer cd of
your device into the cd drive and install the driver
and plug your device on the cable.
Dec 28, 2009 | iRiver iHP-120 MP3 Player
Whenever i am connecting the lg lxu-800 usb modem in my computer it is asking for the device driver software.Although i have the cd,still it is not getting detected.
  1. Disconnect modem from computer by taking out the usb lead from computer
  2. insert modem cd in cd/dvd drive and run install
  3. Install the driver from the cd
  4. follow directions onscreen the restart computer if necessary
  5. plug modem back into usb port
  6. now when windows detects it it will find the correct drivers
Welcome
Jun 22, 2009 | Computers & Internet
I river t10
Install windows media player 10 or 11........ No drivers needed, just the USB cable. Enjoy
Dec 28, 2008 | iRiver T10 MP3 Player
My iriver plus3 software does not detect my iriver h10 player
GUYS ALL YOU HAVE TO DO IS PUSH THE USB CABLE HARDER INTO THE DEVICE. IM A GENIUS!!
Oct 15, 2008 | iRiver H10 MP3 Player
No longer seen by any computer
For me, having upgraded Windows Media Player to version 11 caused the problem you are experiencing. Find a computer with Windows Media Player Version 10, then use iRiver's firmware update tool to install new firmware (version 1.77), then your T10 will work fine even with Media Player Version 11.
May 12, 2008 | iRiver T10 MP3 Player
Iriver plus 3 software issue
i have vista and had the same issue even though plus 3 worked the first time i installed it (might be an issue with the safely remove hardware icon not available most of the time in vista), so now i use windows media player to sync to the device and works fine
Dec 14, 2007 | iRiver clix 2nd generation MP3 Player
Pawn shop deal
the iriver series by default is not detected as a usb drive. iriver music manager is needed to transfer files. After a firmware upgrade, the device is usable as a usb hard drive. But you need the music manager software to upgrade
May 02, 2007 | iRiver iFP-795 MP3 Player
Iriver T10
Somehow the driver went missing. Click on "My Computer" and then click "view system information," then "hardware," then "device manager," then click on iRiver (it'll be there even without the driver) and then it will give you a yes/no option to look for driver software. Obviously, click "yes" but notice that you are also cued to put in a CD "if you have one." I still had the CD. It will search both the CD and online for a driver, but the computer found the driver software on the CD. Make sure you only put the CD in when cued to do so. If you don't have the CD, then contact iRiver about getting a driver download or having them send you a copy of the CD.
Mar 12, 2007 | iRiver T10 MP3 Player
iRiver T10 MP3 Player Logo
3,475 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Mohammad Abumuailek
Mohammad Abumuailek
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
