SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
SOURCE: need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
SOURCE: Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
SOURCE: Cuisinart coffee maker grinder stuck
Same problem and I'm the husband that always got it unstuck...... until this morning. I read somewhere that putting the whole machine in the freezer will work. I did and the grinder just lifted out without any pressure at all! My wife was laughing at me when I was looking on line for a solution but she just smiled when it was removed.......
SOURCE: cuisinart burr coffee grinder
Take out the bean chute, remove the burr from the bottom. Then cut a business card the size of the burr and use it as a spacer between the burr and bean chute. This will space you burrs closer together giving you a finer grind. If there is a squealing sound the burrs are touching and need to be back off a bit.
