Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic rear projection model #- PT53WX53G will not turn on.
When I try and turn the tv on the red light blinks 3 times waits 6 seconds then repeats over and over again, tv worked fine up to now there was no sign leading up to this
Happened to me, relays, either 1 of 2 so I had both replaced, about $300.00 to fix.
Posted on Nov 24, 2008
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Iturn my Panasonic projection tv onand it turns
Thats the error for convergence failure. You can get the PT53WX53G convergence repair kit at www.tvrepairworld.com the kit contains the parts and CD with instructions.
Oct 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Sep 08, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Resistor identification
Hi fccjben;
The color code is as follows: blk = 0; brn =1; red = 2; orange = 3; yellow = 4; Green = 5: blue = 6; violet=7; Grey = 8; white = 9
Unfortunately, if it is wirewound, they usually printed the resistor value on the body of the resistor. For sure it shouldn't be glowing. Sorry I can't be more help, but without a schematid, can't do much else
Good luck Loringh
Panasonic cinemavision pt53wx53g
how many times does the power light blink, as thats a code . also can you send a picture of the item that your referring to that flickers, and I will be able to help you figure it out.
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
