Question about Dell 5650 Computer Speakers
My speakers keep fading in and out
I'd be playing a game, or a movie and the sound/volume would fade out for a period of time and then pop back again.
It would be great to get some insite on this.
  • 2 more comments
  • Jivix Mar 18, 2009
    Same problem here. Seems that a lot of people are having problems with these speakers, leading me to believe that there is a massive hardware flaw in the design of these speakers. The annoying thing is that you never know when the volume change will occur. Sometimes it is right after you turn them on, sometimes a few hours later. Very annoying if listening to music quietly late at night just to have them start blasting and having me jump out of my chair.
  • meme303 Apr 08, 2009
    My speakers keep going completely off then popping back on at high volume suddenly. Going off, coming back on, going off and on. What can I do to fix it?
  • Jivix May 25, 2009
    Hey it's me again. I completely gutted the subwoofer assembly. My theory is that since the subwoofer doesn't get that great of airflow, and so perhaps the amplifier chips are overheating. Most of them were connected to heatsinks, but 2 weren't. I connected them to the heatsinks with copper wire and solder, and mounted a fan on the top of the case to draw out the flaming hot air. It reduced the base about 40% but the air inside of the case got up to about 150°F at least so it was worth it. I thought the problem was fixed but it just started doing it again after a month of use. I have a feeling it may have to do with the crummy center speaker assembly. Hopefully its just a problem with the volume knob.
    New Friend:
TRY THIS :
Right click the speaker icon on the taskbar
Click "Playback Devices"
You should get a screen titled "Sound"
Click the communication tab
There is a set of radio buttons titled: "When windows detects communication activity:"
Select the "Do Nothing" option.
Edit: The issue was present for me if the mic was on or not. A little concerning to say the least...
This fixed the issue for me. Hope it helps someone else.
Posted on Aug 23, 2015
I am having the same problem with mine. Tried re-installing the sound drivers but that didn't make a difference. Took out all the screws in back to see if there was a loose wire, but couldn't get the center speaker apart....
Posted on Nov 20, 2008
How do I get the radio to stop playing outside the trailer?
There should be a series of buttons marked A. B and C. A is for the living room, B is usually for the bedroom and C is outside. If it is a carstereo type system you will need to go into the setup mode where you will find the balance and fade. Balance left and right to see if it turns off the outside. If is does not then fade front or back and see if it turns it off.
Mar 02, 2014 | Heartland Torque TQ 290 RVs
Renault clio radio not working
Speakers dont usually fade away. IT sounds like there is something in the radio that thinks the volume control is being pressed.
Dec 16, 2013 | Car Audio & Video
My amplifier fades in and out. Problem started all of a sudden and got bad really fast. Now it never fades back in, but it used to. What could cause this? thanks...
The most likely problem is a bad ground. The ground wire should be solidly connected to the vehicle chassis in a paint-free location. If it is loose, it could cause fading in and out. Other than that, check all of your speaker leads and the leads from the head unit. It is possible that you have a shorted speaker or speaker wire. Check this by unhooking these leads one at a time and then playing a little bit of music, and seeing if the fading stops. However, I will say again, the most likely problem is a bad ground.
Mar 03, 2011 | Car Audio & Video
Radio continues to fade in and out, plays for awhile fades out
Need more information on this if possible.
It may be the speed volume is enabled on your radio, does it fade out when you start to come to a stop? Some vehicles have a speed volume setting in their radios in which the radio raises and lowers the volume during driving conditions, like when your comming to a stop, the volume will automatically lower and during faster driving speeds will rise to a higher volume.
Hope this helps
JD
Sep 10, 2009 | 2001 BMW 325
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
2004 cavalier speaker wiring
Here is a link that should help you, if you need any more help, Keep me posted, be glad to help. http://www.installdr.com/Harnesses/GM-Wiring.pdf
Jun 19, 2009 | 2004 Chevrolet Cavalier
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
L or r speakers will not play when the volume is low
sounds like you have a wiring problem or the amp is bad. take it to a stereo shop.
Nov 16, 2008 | Eclipse (XA1000) Car Audio Amplifier
Dell 5650 Computer Speakers Logo
2,132 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
