Question about Samsung DVD-V2000 DVD Player/VCR
DVD tray closes on it's own
I am having an intermittent problem with my Samsung DVD-V2000 combo unit. When I am loading a disk into the tray the tray will close on it's own. This happens without ever touching the open/close button on the deck or the remote. I am concerned about squeezing and scratching my disks. It seems the vibration of the loading disk into tray triggers it to close sometimes. Is there a way to program machine so tray only closes when the open/close button is pushed? Other than that it has been an excellent machine. Thanks for your help.
4 Suggested Answers
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
SOURCE: Samsung DVD-VR330: Disk Tray won't open
The solution is to unplug the machine and wait 10 secs. and plug it in again. I have to do this often. another part of the problem may be that some of the blank disks are bad. I got the DVD+R at Staples and about 4 out of 10 were able to be formatted. I am about to try the DVD-RWs.
Posted on Mar 14, 2009
SOURCE: DVD disk tray will not open at all
had the same problem the mechanism for the door opener is faulty.........waited for 2 months to be finally told by samsung part is no longer available......wonderful back up service isnt it. Luck have it I had an extended warranty and getting it replaced with a LG combo
Posted on Jul 08, 2009
  • 1188 Answers
SOURCE: I can't load /unload DVD disk
This could be due to one of several reasons. It may be that the tray is stuck inside the rail. OR it may that the tray drive motor be faulty. You can check by putting your finger on the tray front and pushing the open button: if there is a faint vibration then a click then this is a tray jam. If no vibration is felt then the drive motor is faulty. You state that pushing the button displays OPEN so it seems that the button is ok. Now if the tray is stuck what you can do is open the drive mechanism, check whether there is a rubber band which is involved in opening or closing. Replace that band with a new one from an electronics store. Also clean and grease the rail with alcohol. Please note that ONLY ATTEMPT it if you are familiar with opening drives and are out of warranty. If you are not easy then you'll have to go to a technician. AND if the motor is faulty this would also require soldering.
Posted on Jul 23, 2009
0 characters
1 Points
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
Apr 03, 2010 | Panasonic DVD-S25
The DVD drawer won't open and close on our Go Video VR3845 combo. Help.
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Dec 31, 2009 | GoVideo VR3845 DVD Recorder/VCR
The tray wiyll not stay closed and sometimes will not open or closed.
maybe you have bad contact in micro timing switch, and this micro switch needs cleaning then test run.
Jun 06, 2009 | iLO DVDRH04 DVD Recorder
Jun 03, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
LG V271 DVD VCR Combo problem
try cleaning the player. with a dvd clean disk..for about $5.00 to $7.00.... and wipe down the player.
sometimes dust and trash gets in the way and will not close properly and you end up closing an closing until the trash get out of the way... cleaning it will help..
Apr 14, 2009 | Sharp DVRW250 DVD Players
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Samsung DVD vrc combo
Something like this happened to me befor, it turned out in the end the button was punched in; interfearing with the DVD system.
Dec 08, 2007 | Samsung DVD-P144 DVD Player
Samsung DVD-V5500 DVD tray intermittently wont open
Sometimes the loading belt can cause this problem or else have seen the tray in switch assy cause this as well.
May 23, 2007 | Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V2000 DVD Player/VCR Logo
217 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
