Question about Kirby G6 Bagged Upright Vacuum
My Kirby 2000 will not turn on?
My son got mad at me and kicked the vacuum and knocked the drive lever off the back, the vacuum did still run but was stuck in N. I was able to reassemble everything by removing the wheel plate on the bottom. I reassembled the vacuum and lever but when I tried to test the repairt... NO POWER!!! Any ideas.
  • djea6b Dec 24, 2008
    what holds the drive lever in place? Mine just fell out the other day. Vacuum works but stuck in drive
  • Kirby Expert
  • 324 Answers
No power is usually when there is nothing installed on the front or bag is improperly installed. There are 2 safety switches that must be pressed in order for Kirby vacuum to work. So make sure you have the nozzle on the front and when installing bag assembly - push the plastic bottom part to the vacuum as far as it can go.
Posted on Nov 18, 2008
Kirby g10d, I shampooded the carpet then put it back together and it wont start 4/12 yrs old used approximately 50 times. Any ideas?
Make sure the emptor at the. Bottom of the bag assembly is turned all the way clockwise. It pushes in on lever on the switch. It won't run if the lever is not pushed all the way.
Jan 31, 2015 | Kirby G10 Sentria Vacuum Cleaner...
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
KIRBY 5 PROBLEM
make sure the lever it the very back of the machine is in the on or drive position, make sure the height is up high enough ( the higher the better as long as it is still cleaning - lower is not better ) and change the belt even if it isn't broken they can stretch out in less then a year of use.
Sep 19, 2008 | Kirby G6 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Dec 24, 2007 | Vacuums
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
253 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
