Question about LG RUMOR Cellular Phone
Lg Dare phone
I sometimes get a shortcut icon on the main screen and can't get it off the mainscreen any suggestions. My actual shortcut screen is fine.
Thanks
  • 1 more comment
  • Anonymous Dec 09, 2008
    thanks, i had the same problem and its fixed!
  • bzaffino Jan 07, 2009
    What arrow? I don't see any arrow that opens up the shortcut list. Tell me what part of the screen. I have tried moving the icons all over the screen with no luck.
  • Zarcc May 11, 2010
    Which shortcut icon? On most phones you can change the shortcuts under a setting called display or shortcuts. Have you tried doing a power cycle (removing the battery for a few seconds and then turn it back on? This often removes a lot of problems due to a software loop.
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Posted on Dec 19, 2008
  • vijendra_jay Feb 03, 2011
    thank you, my problem solved
If you dont have an arrow in the upper mid right side of your main screen. go to call settings>display settings> turn on shortcut bin.
the arrow will appear, drag and drop it on the arrow and then go turn that shortcut bin arrow off if you dont want it there.
Posted on Jan 26, 2009
You need to drag the icon back onto the arrow that opens up the shortcut list. This will remove icons from the desktop
Posted on Dec 08, 2008
The touch screen on my LG Dare keeps vibrating and activates different commands, calls, etc and sometimes it won't respond to actual touches
Hi, when a phones touch screen malfunctions, it means that the touch pad is damaged seriously and it needs to be replaced.
Mostly it is caused by dropping the phone on the flow, hitting it on something or even pressing the touch screen pad with the wrong instrument.(any sharp object).
You can take it to a here by store for a replacement.
NOTE: phone is very delicate needs to be handled by an experienced personnel.
Take care.
May 19, 2010 | LG Dare VX9700 Cell Phone
HOW DO I REMOVE ICONS FROM MY LG DARE PHONE
if u have the shortcut bin on the middle top right of your screen, it has a little arrow, just drag your icons to the arrow and your icons should hide inthe shortbin.
Jan 05, 2010 | LG Dare VX9700 Cell Phone
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
How do i remove icons
Drag the icon over to the shortcut tab and drop there. It will disappear. There won't be any indication that this is what you are doing until you lift your finger / stylus.
Sep 23, 2009 | LG Dare VX9700 Cell Phone
How to pairing lg dare w 2005 bmw 750..?
You most likely have to set your Dare to Discovery Mode and have the BMW find it first.
With your Dare browse to:
Main Menu -> Tools & Settings -> Bluetooth Menu
At the bottom right of your scree next to "Show" touch the options menu icon
Select "Discovery Mode"
Then follow the directions for your BMW to find the phone.
Sep 20, 2009 | LG Dare VX9700 Cell Phone
Unresponsive touch Lg Dare Touch screen
sometimes you just need to take the battery out and put it back in. If you've already done that then you may need to take it to Verizon and get it updated.
Jul 09, 2009 | LG Dare VX9700 Cell Phone
Boy friend locked LG Dare to keep me from using it. Need unlock instructions or master reset
Send me your IMEI. This is a 15digit number that you receive when you input *#06# on the phones main screen. I might be able to help you then.
Jun 02, 2009 | LG Dare VX9700 Cell Phone
Calendar button appears on the Main Screen
All you did was drag it on accident to the main screen. Just drag it back into the shortcuts menu.
May 12, 2009 | LG Dare VX9700 Cell Phone
How do i take pics?
Well, the easiest way is to use the botom button on the right side (edge) of your phone.
The other way is to press the Main Menu button on the main screen. This is the middle icon at the bottom of the screen that has 4 dots then go to Media Center.
Select Pictures & Video then Take Picture.
Point and press the camera button (bottom right edge)
To switch between Video and Pictures, press and hold down the camera button until either the camera icon or the video (movie camera) icon appears.
Once you take the picture, you have to select the second icon down on the right to save it to the phone.
Apr 09, 2009 | LG Dare VX9700 Cell Phone
How do i get a short cut off home screen
you drag the shortcut with your finger to the corner of your phone where the little blue arrow is. it should go away
Mar 14, 2009 | LG Dare VX9700 Cell Phone
LG RUMOR Cellular Phone Logo
1,235 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
