I have an old Panasonic RF 888 portable radio. It is in excellent condition, except the volume is very low and scratchy.
Have you tried opening up the radio and spraying contact cleaner into the volume potentiometer? This is a common problem in older electronics. The RF 888 has 4 screws on the back. Remove those and you can lift off the back cover. (Be careful because those screws pass through the center of the radio and hold the front cover in place.) Get some electronic cleaner at Radio Shack and spray it into the small opening on the side of the volume control. Rotate the volume several times and let the spray evaporate and see if things sound better.
Posted on Nov 30, 2008
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
Why is SSB reception (volume) extremely low?
If you have AN RF gain knob on this radio then turn it wide open.
Feb 12, 2016 | Radio Communications
Low volume controll
In recent years public service and all land mobile has moved to narrow band FM from the old 12.5khz or 5khz bandwidth FM to new 2.5 and 1.25 khz format.
The older scanners will play these transmissions with much lower volume and there is nothing that can be done to the scanner to solve this.
You can buy an amplified speaker and use that to further boost the audio or just replace the scanner with a new scanner built by Uniden or GRE (General Research Electronics) who make almost every scanner on the market. Both are good units.
Mar 06, 2014 | Radio Shack Pro-83 Portable Handheld Cb...
Audio is very scratchy/static
If it makes a scratchy sound when the volume is turned up and down then the carbon contacts on the volume control are most likely the culprit you can attempt to clean them with rubbing alchol and a Q-tip.
Jan 17, 2010 | Midland F-12 (14 Channels) 2-Way Radio
Scratchy noise from. ... Denon Power AMPLIFIER POA6600A. Randomly with some hours betwin.
1-apply spray contact cleaner from radio shack to all volume controls of the amp and move them forward and backward-check your cables must be in good condition,otherwise change bad one with brand new one.
Jan 07, 2010 | Audio Players & Recorders
Scratchy dials onGeneral Electric AM Fm tabletop radio
both switches need a good ceaning. go to radio shack get some contact cleaner. Make sure the radio is off take off the back spray contact cleaner into the switch while turning them back and forth. wait till dry.
Sep 14, 2009 | Audio Players & Recorders
Have a Motorola XV2100 VHF two way radio that works well except the volume control must be turned all the way up so you can hear it. The radio is about 5 years old and was never used very hard. Even with...
Hi Ed,
The VHF radio that is quiet, does the Speaker have a rattle, even very slight? if so that speaker could be faulty, and /or also does the volume control make a scratchy noise when you rotate it?
if so this could be faulty try some CRC down the shaft let it sit for say 15 minutes then rotate the conrol from stop to stop a few times.
To service--- well, would pay you to get a quote first from one or more service establishments if repairs are required.
Good luck,
John.
Apr 06, 2009 | Motorola XV2100 (1 Channel) 2-Way Radio
Volume control inoperable
spray some tuner cleaner in the volume and rf gain pots and work them back and forth. Have you tried an external speaker to see if stock speaker is blown? Also improperly installed talk back can cause this
Dec 28, 2008 | Uniden Radio Communications
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
135 people viewed this question
 Grubhead
Grubhead
