Question about Eclipse CD2000 CD Player
Eclipse CD2000 has no sound from a cd or sirius... radio works
I have an Eclipse CD2000 which has no sound from a cd or sirius... radio works just fine. CD player display shows it is playing. Sirius display shows song/artist/etc. Any help would be greatly appreciated.
  • 3 Answers
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Posted on Dec 17, 2008
I have same problem but do not have a amplifier hooked up. Any sugestions
Posted on Apr 22, 2009
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security".
ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
Dec 16, 2013 | Eclipse CD2000 CD Player
Have ESN Eclipse radio CD2000 with Serius adaptor installed inside the fairing on a motorcycle. Cannot physically located the serial # on the Serius unit itself or through different funtions on the radio....
The SID # you need to activate that is displayed in two places. On the unit itself, and on channel 0. Try switching to channel 0 once in Sirius mode, and the SID # should be displayed.
May 27, 2011 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Set clock on radio
Try the following website for the instruction on how to set the clock radio.
http://www.eclipse-web.com/us/manuals/manuals.html
Aug 17, 2010 | Eclipse CD2000 CD Player
I installed my cd player but it only plays the radio does play cd's
by "play" im assuming u mean no audio... check the wires, in the back there should be 2 blue wires, one has a white stripe... splice them together or reverse them... it sounds like you have it hooked up to the power antenna wire (should be solid blue wire) is sending power for the amp to turn on only when the fm is playing... you want the amp turn on wire (blue with a white stripe) to be hooked to that factory wires so when the radio is on your factory amp is triggered... if that doesn't work let me know there are other thing you can try...
May 02, 2010 | Eclipse CD2000 CD Player
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
IS there a left and right audio input in the rear
No, the RCA jacks on the back of a CD2000 are line-out, not inputs.
Feb 04, 2010 | Eclipse CD2000 CD Player
How to hook up sirius radio with cd7000
all you will need is the eclipse ecl- sc1 module and a subscription and you will be off and running with this deck
Sep 24, 2008 | Eclipse CD7000 CD Player
Eclipse cd2000 car stereo
does it have a reset button or switch.. usually found on the underside of the face plate
May 09, 2008 | Eclipse CD2000 CD Player
ECLIPSE CD5425 LOCK CODE
throw it in the trash no good cant reverse
Dec 23, 2007 | Eclipse CD2000 CD Player
Eclipse CD2000 CD Player Logo
354 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
