I have tried retuning several times and I can't get channels 1-9. Do I need a software update or maybe a new ariel. I don't know what is wrong as the first retune on the 4th April I received all the channels.
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
You have a life right your will will or should find the answers you need so just take your time and figure it out if you truely want to you will
Thank you for your solution. In the end I did a manual re-tune and found all the channels and programmes. It takes quite along time but is worth it.
