Question about Kenmore 22422 Top Load Washer
Washing machine filling with water not finishing cycle
Last 2 loads washing machine would fill w/ water and then stop... I found out by accident that if I bumped it (hip bump) it would then run... so I did this on those 2 loads, now it is full of water and will not do anything. Do I need to call someone or is this something I can fix?
  • sksliwinski Nov 17, 2008
    I thought of that and had checked to make sure switch was in as far as possible... it is... I put butter knife in there to make sure. :( Would have been nice if that would have been fix. Anyway, so any other ideas... also switch needs to work in order for washer to fill for me... and washer does fill, just does not agitate or continue on. I think it was not perfect level, although not bad either. Would that keep it from agitating? Was weird for 2 loads it would start working again with hip bump?
  • babyslapnuts Nov 17, 2008
    I have a wahing machine is filled of water.
  • 1,028 Answers
Probably just a bad lid switch or best case loose hinge screws if lid switch is located on right side of lid opening try pressing it down with a pencil or small screw driver if works replaced lid switch by removing console screws under end caps or if newer modes switch located under rear hinge area remove console by pressing clips at lower edge each end of console ..remove brass colored clips on older model and pull cabinet or newer model switch is mounted to top of cabinet under console
Posted on Nov 16, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Aug 31, 2010 | Frigidaire Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 22422 Top Load Washer Logo
60 people viewed this question
Sal De
 Brian Main
Brian Main
