Question about Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook
My battery will not charge on my dell studio 1749 laptop. I ordered (from Dell) a new battery and a new adapter plug in. Still won't charge - the light blinks amber several time and then once wh
Will not charge and the battery and charger\adapter power cord are brand new.
  • Sherry Wasdin Apr 22, 2012
    The dc power jack continuously blinks 4 times amber and one white. The power light blinks. I don't know how to check power supply to see if its putting out voltage to laptop.
    I removed the battery and the computer will run with the power jack plugged in so I guess this brand new, two month old dell battery is defective. Now to try and get someone that can help me at Dell.. It is hard just to find a phone number for them to report this type of problem.
    Top Expert:
  • 5,051 Answers
Great story, but I feel your pain. There are so many times people think that just because they bought it new it works. Not true at all.
Posted on Apr 23, 2012
Testimonial: "Thank you so much for your comments. They did help me tremendously."
SOURCE:
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
SOURCE: Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
[email protected]
Posted on May 24, 2009
  • 629 Answers
SOURCE: on screen display of dell ac power adapter not
2 possible causes, faulty adapter or faulty motherboard. try to update the BIOS if applicable. If this does not work, attempt to test the adapter on another laptop to confirm if it is working, or try a confirmed working adapter with your laptop. If same issue with another adapter, or if your adapter works with another laptop, it will be a motherboard problem. If the adapter fails on another laptop or if another adapter works with your laptop, you'll need to get a new adapter. Hope this sheds some light. Feel free to rate the usefulness of the information.
Posted on Nov 04, 2010
SOURCE: dell latitude d600 blinking battery light
Sometimes a systemboard will cause this,
Posted on Mar 16, 2009
  • 15 Answers
SOURCE: My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
Posted on Mar 29, 2009
Dell Studio 1749
Possibly a GPU, RAM or CPU issue.
Try re seating the RAM and CPU.
Jan 09, 2014 | Dell Studio 17 (1749) Laptop black -...
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
My computer does not have a mass storage controller or network controller driver - Dell Studio 1749 laptop
Hello stwasdin,
below is the link where you can download the driver.http://www.dell.com/support/drivers/us/en/19/DriversHome/?c=us&l=en&s=dhs&cs=19
thanks.
Apr 19, 2012 | Dell Studio 17 (1749) Laptop black -...
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
On my dell studio 1749, my charger works, my battery works, but when the battery is fully charged and it is also plugged in it randomly shuts off. that makes no sense to me. if the charger failed the...
Your computer sounds like it is overheating. Make sure the area where the fan blows the hot air out of is not obstructed, if there is a colder room in at your location try moving there. If your problem persists you may want to invest in a laptop cooling pad which is basically just a platform with additional fans to cool your machine. If you don't want to buy one you can just set up a normal fan to blow on your computer.
May 31, 2011 | Dell Studio 17 (1749) Laptop black -...
Dell studio 1535 not charging
Without testing the complete power circuit there is no way to know what needs replaced. the motherboard will most likely cost as much as a new laptop though. They are like the LCD screens. You can buy a new laptop for 4450 now days but to replace a motherboard or LCD screen you'll pay $500 to $700 not counting labor.
Jul 26, 2010 | Dell Studio 1535 Notebook
Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook Logo
1,457 people viewed this question
Ekse
Clive
Clive
