Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Can not get to p-menu on the LCD screen
Just a plain Menu comes up on the LCD Screen. I need to get to the P-Menu for all the different functions. Please help me. Thank you
You have to turn off the Blue light by pressing the "Easy Button"...took me an hour an 1/2 to figure this one out.....geeeee
Posted on Jan 20, 2007
I have a Emerson 42 inch LCD TV.. power comes on,and the screen lights up. But does not display any images. Not even when you push the menu or the input menu button
first of all make sure you are on the correct video stream.. (HDMI 1, HDMI2, etc) of Aux , Com.. or just plain ole Channel 3 or 4,, if all that fails it sounds like it might be your T-Con card. I had the same problem with TV I fixed for a friend and that was an easy fix. in fact he just gave me the TV after I fixed it. and it is still working.. I usually check with Shopjimmy.com for parts. if they don't have them in stock then I check with eBay,Amazon. or just Google the part number and find one there..
Sep 22, 2014 | Televison & Video
Lg w2343t monitor
try monitor on a different working desktop to see if it works, both on the external and internal video card ports. If screen menu buttons fails to respond, fault is either on menu buttons or you may have a burned out lcd screen, try a different monitor on your desktop pc to check its functionality. Monitor probably needs replacement.( It might not be burned out for you mentioned "no signal" error message appeared on screen, have the screen menu buttons checked)
Dec 28, 2013 | Computers & Internet
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
When i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Jul 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
D40 menu screen problem
i'll give you 2 solutions for this one
If you are talking about the MENU that shows up on the picture regarding the ISO, FLASH, APERTURE, WHITE BALANCE and Whatnot, you need to press the up arrow or down arrow buttons on the directional keys to remove the menu on the button
but if you are talking about the MENU which you can tweak different settings you just have to do a half-press on the shutter release button which will turn off the screen.
Apr 23, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Menu keeps popping up; Stuck buttons perhaps?
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Dec 23, 2008 | Dell E153FP 15" LCD Monitor
Dell 924 all in one will not print magenta
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Nikon d40x LCD screen stopped working
Have you tried the 'Menu' button? If you've turned off 'Review' in the settings menu, the screen doesn't show anything after you take a picture. If the screen doesn't come on when you push the 'Menu' button with a charged battery installed, your camera will need to be repaired.
Dec 25, 2007 | Nikon D40x Digital Camera
LCD Screen stopped working on camera.
Have you tried the 'Menu' button? If you've turned off the 'Review' feature in the settings menu, your LCD screen won't show anything unless the 'Menu' button is pressed. If it doesn't come on when you push 'Menu' with a charged battery installed, your camera will need to be serviced.
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
