Question about Microsoft Windows XP Home Edition
I have no audio
The sound on my computer won't work. I troubleshot and narrowed it down to my audio device not being active
    Champion:
  • 253 Answers
Try ac97 driver for realtek
Posted on Nov 18, 2008
Sound card won't work
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 04, 2012 | Computers & Internet
My Z205 worked when I first got it, but now it won't work. I have plugged it into another laptop and it's fine. I have tried all ports but no luck. The light comes on the speaker top so I know that...
If your using windows 7 go to the volume control in the taskbar right click it and select playback devices then make sure the speakers are set as default by clicking the speakers and then click set as default.
May 17, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I Install Office XP Service Pack -2 it works good but audio is not working, when i go to troubleshotting option it suggest me to go to accosseries entertainment volume control "There is no active mixer...
if you have the installation cd of mother board, then in that cd the programme for sound settings is avilable. you just install that one( for example in the case of ASUS mother board it's name is nvidia nforce) . if you install it your problem will be solved
Sep 14, 2010 | Computers & Internet
No audio device
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Sep 01, 2008 | E-Machines eMachines Desktop PC
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
No audio device
dear worried girl ,,try this some times systems will not reconize a new product try unstalling complete thing and reinstalling it .unhook it (sound card )uninstall software turn pc off. reinstall hardware first go to install hardware in your controll paniel and then and the new driver for it ... email me tell me what happens linda
May 08, 2008 | Intel Creative Labs Sound Blaster 16 PCI...
60" rca hdtv power button blinks on and off 3 times then shuts off.
the set will have to be troubleshot further to narrow it down. the set contains a processor that has shut the set down. as a tech i have special computer that can read the errors. One thing to try is to uplug the set for about 30 min the plug in listen for anyh sounds. if the light blinks...its not the main fuse.
Dec 31, 2007 | RCA D61W20 61" Rear Projection Television
Sound and audio devices problem
all the options in sound and audio device properties are in active no sound is heard
Dec 17, 2007 | Edirol UA-4FX External Sound System
Speakers work...just not when plugged into desktop
This is a duplicate post, click the following link to view the active posting: http://www.fixya.com/support/t129710-speakers_work_just_not_when_plugged
Jan 08, 2007 | GE HO98005 Computer Speakers
This is a duplicate post, click the following like to view the active posting: http://www.fixya.com/support/t129710-speakers_work_just_not_when_plugged
Jan 08, 2007 | Gateway GMAX 2100 Computer Speakers
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
