Question about Toshiba 57H94 57" Rear Projection HDTV
NO HDTV I can't get the local HDTV channels. I had a smaller TV that I replaced with this one and it received all the local channels. There doesn't seem to be a option for HDTV search or any other way to turn those channels on. Can you help? Thanks
  • 3 Answers
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Posted on Dec 28, 2008
How do i get local digital channels
The HDTV tuner in the set must be of proper spec for your area. This is the start. At the rear you should have an RF connector. You will need to connect an HD type TV antenna. There are indoor TV antennas available. These work okay if the signals are strong enough. It is best to use an outdoor and mount it on the top of a building in order to have proper line of sight reception.
If you are sure your can meet the requirement with your TV and location to receive local TV stations then go in to the menu of the TV set and let it do the auto setup to receive local TV signals. Depending on the are for where the set was sold, there should be some prompts to satisfy about the type of signals that will be received. Once set, let it do the auto setup. This can take a fair number of minutes.
May 13, 2014 | Olevia LT37HVS 37 in. LCD HDTV
Failed to received broadcast E202. what's wrong?
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Hi My LG 52LB9DF tv is slightly blurry - I'm not sure if it's the size or quality of the tv? Even the HD channels are slightly pixellated. My friend has a smaller tv with a much sharper resolution....
1. Your TV has a digital tuner built-in, you do not need a set-top box to receive local digital channels.
2. Try to disconnect the box, hook up the antenna directly to the TV antenna input & program the tuner, you may getting better picture.
Aug 29, 2017 | LG 52LB9DF LCD TV
Now receiving local channels. i switched between
Go in the tv menu go to PICTURE go down to reset.Let the Tuner board go back to factory setting.Go to CH. pick Cable or Air rescan it again,all the chanels,it will be there.
Jun 14, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 57H94 57" Rear Projection HDTV Logo
232 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
