Your Dell D620 only has a VGA Port for output to a external monitor or tv. Your TV will need to have a VGA Port too, otherwise you will need some type of adapter that goes between the laptop and the tv to convert to the type of connection the tv has (svideo, hdmi, dvi, etc.)
One you have the two connections set up to communicate with each other, just select the input source on the tv (pc, computer, hdmi, etc) and then reboot the computer if the image is not show.
After rebooting if the image is not shown, then you will need to toggle the display by some keystrokes. Press and Hold the Fn function key at the lower left hand portion of the keyboard, then hit the F8 key which toggles the display to be either on the laptop only, tv only, both the laptop and tv.
