Goodman A49-20, tranformer burning up
When I turn the unit on, after a delay, the fan in the attic/blower unit comes on, after about 1 minute, the transformer smokes. The internet said to check for wires that are shorted. I did a resitance check on all wires after disconnecting them from the terminal blocks and they all checked out good. I had a service tech come out, I live in the country, 45 miles away from the closest, 90 miles round trip. All they wanted to do after replacing the transformer and it burned out,was to replace the entire unit quoted $2,500, I am trying to avoid this charge.., again the fan/blower works so I don't see why I need to replace that unit, maybe the compressor is bad, but the tech said that was not the problem, however, I never heard it come on. ideas please.. maybe something as simple as a capacitor or a switch?
  • grantwf Dec 14, 2008
    I hear the blower making a buzzing noise when it comes on .. then there is a puff of smoke, a smell of burned wires as the fan starts ... briefly ... and then it's fine. This is not consistent ... happens once every few days.
  • 31 Answers
The blower fan comes on,sounds like you have a dead short,check wire connections on transformer,check for burned contactor
Posted on Nov 16, 2008
The goodman air conditioning unit will randomly turn on and run for a few minites then turn off. The blower fan does not run just the unit in the attic. Any advice?
Hi, not enough detail not enough detail. I have no idea where you are located, but if it is a gas heater/ Ac then maybe the attic space is so hot that the over temperature sensor is turning the unit on in an attempt to cool the system down. If however it is a refrigerant AC unit, I would suggest that the control circuit is faulty, maybe a sticking contact somewhere. good hunting col
Feb 24, 2011 | Heating & Cooling
Goodman GMPH075-4 Heater with new louder noise & strange smell
The burning smell could be anything inside the furnace blower compartment. Most all the controls are located there. Me not being there is it hard to say what it it and what to replace. I would start by removing blower compartment cover and inspecting the wires and controls. Look for any bad connections. If it was transformer it would have already burnt up. Goodman has a fuse on there controlls in case of shorts, Limit controls in case of unit over heating. If you cannot visably see anything wrong it would be a good idea to call a service tech to check heat exchanger. I would have it checked anyway. James
Mar 26, 2010 | Heating & Cooling
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
My Goodman air handler RELAY, ELECTRONIC BLOWER TIME DELAY makes a clicking noise 4 or 5 five cycles (about 10+ Sec delay ) before the squirrel cage fan will come/stay on. I have reset the unit by switch...
when this happens turn off power and feel motor if hot capicitor i dont think this board cost much but if it does you can get a fan sequenseing stack switch to repace the board with
May 12, 2009 | Heating & Cooling
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
Furnace blower needs repair
Hi,may be your Fan motor shorted ,pls check the that lead wire of FM.
Regards,
Edgz
Feb 08, 2008 | Goodman CPLE24-1 Air Conditioner
PROBLEM
Thermostat wires or solid state control, (time delay board) sounds like your symptom.
Nov 28, 2007 | Ruud Central System Air Conditioner
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
