Question about Sony KP-53HS10 TV
Blurry picture I have sony tv kp53hs10 and the picture is blurry do you have any idea what it could be?
  • Anonymous Jun 17, 2008
    Picture is blurry...red and green go bad..bouble picture...
    Problem Solver:
  • 3 Answers
I Just had the same problem with my Sony KP43HT20, was a blury picture with the red & green going bad.......My set had defective convergence IC's, they are known to go in Sony's..IC's run about $30 a piece. Good Luck.
Posted on Nov 26, 2006
SOURCE:
Sony kp53hs10 stand flashes
If your using composite video with the red green and blue, make sure the green and blue wires are connected to your TV right and not reversed.
Jan 11, 2014 | LG Televison & Video
My Sony kp53hs10 turns on and has a picture but in afew seconds the screen goes blank and I see 7 blinking lights. Any ideas?
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply section..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Sep 14, 2011 | Sony KP-53HS10 TV
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Sony kp53hs10
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Dec 22, 2008 | Sony KP-53HS10 TV
KP53HS10 power supply board
you can check here or leave a post that you are looking for one
http://www.tv.quuq.org/forum/index.php
electech
Oct 23, 2008 | Sony KP-53HS10 TV
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
I have sony 53 Projection TV Model No KP53HS10
First check the batteries in your remote. if that doesn't work check the setup menu. see if you have any kind of auto on\off, alarm, snooze or enabled. some of Sony's tv's had these features
Oct 08, 2007 | Sony KV-32CS70 32" TV
Sony KP-53HS10 TV Logo
302 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
