Question about Panasonic CT-32SF35 32" TV
Tv color My Panasonic tv(ct-32sf35)does not show color properly, looks like only a few colors work.Grey,Red,Pink,and Green. The picture is there but hard to tell what is actually going on.
  • 398 Answers
The solder joints on the degaussing thermistor have cracked or the thermistor itself has opened, and the CRT is heavily gaussed. You can degauss (demagnetize) the picture tube and the colors should return to normal, but the thermister should be resoldered or replaced.
Posted on Jun 26, 2007
What color options do I have for the KARLSTAD sectional sofa from Ikea?
There are quite a few color options for this sofa including white, grey, dark grey, brown, beige, green and a pink-red color.
Aug 14, 2012 | Furniture
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projection tv 42" panosonic hdtv. to much green in the picture. Jeff
this unit may have a resistor on the green crt-board that has increased in value. check ohms(resistance) on all crt boards and compare to one another. these will have color bands that inicate value of resistance. you do not need to know color code, just match colors of resistors on each board then measure. you could also have weak green tube. turning down the master screen control located on the fous/screen block can reduce grn. drive. to adjust proper drive for each so the grey scale is correct, turn color to tv all the way down then adjust screen controls on block for black & white picture. when color is turned all the way down, you should not have any green, red, or blue over cast on screen. mch
Feb 20, 2009 | Panasonic PT-51G35 51" Rear Projection...
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
Panasonic CT-32SF35 32 On & Off, On & Off
Bad capacitors in the standby power supply most likely.
Jun 09, 2007 | Panasonic CT-32SF35 32" TV
Pink screen
Is your grey scale or Black and white programming pink?? Thats an indication that the green and blue grids on the picture tube are week or that the red is over driving. First thing is take off the back of the set. Find the end of the picture tube and look at the printed curcuit board there. see if you can find and red drive controls there. Put on a black and white pic and ever so slowly rock that red drive control a little at a time till the picture looks almost normal.. If you get it to be a little \less pink then stop right there but if it starts to get a bit green or blue then try rocking those controls all back and forth till you get the bese B&W picture you can BUT BE VERY CAREFULL as there is alot of voltage on this picture tube and if your not carefull it will bite ya. Now dont be too critical as the tube is a bit weak so you probably wont get a perfact grey scale so if after a while live with it or get a new set. Good Luck.
May 02, 2006 | Jensen Q2749J 27" TV
Panasonic CT-32SF35 32" TV Logo
249 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
