Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic rear proj tx51 p400h wont switch on
Hi there,i have a panasonic tx-51 p400h rear projection tv that at first sounded like it would switch on by the remote control but would not actually start up then after 10 seconds or so would switch off by itself,but now it wont even do that anymore and all there is a small red light on the front panel blinks twice every few seconds.Hope you can help,thanks.
I have the same problem, anyone know whats up?
Posted on Nov 24, 2008
  • justken44 Nov 24, 2008
    same problem here, i've heard it may be a power supply, can i get one with instructions on how to replace it?
My tv toshiba 51'' rear projection wont come on, no sound or image but i hear a click when turn on and off.
most common reason is convergence problem--unsolder both chips and see if set will power up with them out of the circuit.
May 02, 2012 | Toshiba 51H94 51" Rear Projection HDTV
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have a sony projection tv and the screen is curved and blurry.
Need new convergence amp ic's and probably a few resistors.
Cost you about $30.00 for parts.
Search for keyword "convergence".
-dan
Jul 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Jan 29, 2009 | Sony KP-51HW40 51" Rear Projection...
My Panasonic PT-53WX52 rear proj. TV won't turn on?????????
from what I have found out their is a problem with the power unit inside the television. Could be a convergence chip that shorted out
Nov 20, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic tx-51-gf85h rear projection
Hi mate.
The problem is usually he 2 convergence i.c.s.
Breaking down under extreme heat. My fix after replacing these
I.c.s. is to mount a computer fan on the opposite side of the heatsinks and directing a slow and moderate airflow around the i.c.s.
May 27, 2008 | Panasonic PT-51G63 51" Rear Projection...
Color registration doesn't fit. The Blue is hanging to one side and it's a bit wider
Color registration doesn't fit?? Do you mean that you have a convergence problem and that the colors are not aligning?
That set uses two STK392-010 and all low ohm the feed resistors out front of the amp should be checked for change in ohm value: R7051, 7050, 7049, 7048 all of them are 10 ohms 1/2 watt.
Bill
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
