Question about Kenmore Kitchen Ranges
1987 kenmore electric counter unit 911.4358711 2 of 4 burners do not work
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
My Amana ceramic cooktop has one burner that is not working. I can't get the top off to look at the burners. How do you repair one burner on a ceramic cooktop?
Check your warranty first. Some burners on smooth tops had long warrantys. If not first turn the power off to the unit at the breaker. If this is a in counter cooktop it has to come out of the counter and take all the screws out that hold down the top. Best to unwire from house and move whole unit to big surface to work on.
Apr 18, 2008 | Kitchen Ranges
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
134 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
