Unable to increase the picture brightness sufficiently using remote control. Can't seem to find any technical info on the Internet so I thought I?d try here before I crack the access panel to ?poke around?.
Comments:
Nov 28, 2006
- Well since no one seems to be around I'll post what I found out after taking a look inside. No adjustments, plenty of capacitors to run afoul of and one thing of interest. Lots of dust has accumulated in the projection area over the past few years, especially on the projection lenses. I used a clean micro-fiber cloth to clean the dust and cobwebs off the mirror and the lenses. I did note some improvement in the brightness but not enough to make me happy.
Guess I'm off to the repair shop.
Feb 17, 2007
- Thanks forsaken2005, I found this site because of this issue and wound up posting. It was somewhat ironic that up till now never heard anything.
Yes I did clean the mirror and that helped a little bit, the service manual and your tip will probably be the next thing after we recover from our recent snowstorm.
Tom, Have you also attempted to clean the mirror as well as the inside of the screen? Focus as well as brightness issues can arise due to elements on these components as well. I would imagine you are having trouble with B+ V if this is not the case. Also if you have a HV probe you should get the service manual and check each flyback as well as the individual drives. Not familiar with Panasonic s method of return loop but if the voltages are wrong somewhere it will greatly effect performance of the circuit. Hope this helps. :) I smoke and have to clean mine regularly.
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-51HX42 51 in.
Panasonic PT-51HX42 51 in. Rear Projection Television
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on...
(More)
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on a red wire that appears to be connected to a "distributor cap looking thing" that then broke. it appears that it was soldered deep incide the part. What is this and is it bad that that i did this, will it work by just re-securing it in the "distributor cap thingy" or did I just ruin the tv to the point its not salavageable, or is this part i broke replaceable and what is it called?
i have a panasonic pt-51hx42 and when you turn it on after about 3 seconds it turns itself back off...
(More)
I HAVE A PANASONIC PT-51HX42 AND WHEN YOU TURN IT ON AFTER ABOUT 3 SECONDS IT TURNS ITSELF BACK OFF AND YOU HAVE TO UNPLUG IT AND PLUG IT BACK IN TO GET IT TO TURN ON AGAIN
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when...
(More)
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when black. No sound no picture. The power light flashes three times then stops for about 10 second then flashes again three times the stops fpr 10 seconds. Any Ideas?
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is...
(More)
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is distorted and makes viewing difficult.
