Question about ViewSonic VG700b 17" LCD Monitor
White screen on veiwsonic vg700b
What is the cause, and possibly the solution, if any to this problem? i am pretty adept and can repair this if i only knew where to look. or am i wasting my time
    Scholar:
  • 63 Answers
Usually a completely white screen is an indication that there is no video signal being fed to the panel from the controller. For instance, if you take a working LCD monitor and just disconnect the video cable that goes to the LCD panel from the mainboard, it will turn on and off just fine, but it will light up bright white.
So, there seems to be an issue getting the video signal from your logic board to the panel. This can be caused by a bad cable, a loose connection, a bent and/or shorted pin (from plugging it in wrong), a bad logic controller chip, or a blown fuse/component on the LCD's circuit panel (PCB that runs across the top of the back of the LCD panel.)
Hope this help!
Feel free to contact me with questions, or for sales and service.
Chris
Boise LCD
(208) 891-9117
cjmclellen@msn.com
http://BoiseLCD.webs.com
Posted on Jan 15, 2009
Ds lite screen flash white tehm off
its possibly a software issue, babe theres some corrupt data with the os, if it still has a warranty i would recommend sending it in for repair. im pretty sure they only charge 40-50usd for repair otherwise and it would give you a chance to purchase/renew your warranty through them
Mar 23, 2010 | Nintendo DS Lite Console
I have a viewsonic VG700b monitor. Everything is fine for the screen but the built in stereo speakers don't work. I'm pretty sure the wires are in the right place so can anybody help me????
First make sure that you are using the mini stereo male phome jacks on both ends, one end is connected to the Green audio line in of the monitor, the other end should be connected to the Green audio line out of the PC, also need to set the volume controls at the PC and the monitor, starting at 1/2 level. You can also verify that the monitor amplifier is wprking or not by feeding it with an MP3 player or some kind of audio source to see if you do get the sound OK.
Mar 14, 2010 | ViewSonic VG700b 17" LCD Monitor
Tv screen went white but can still see picture
There is a defect in the video output circuit which feeds the signals to the picture tube. Unless you are technically inclined and adept at desoldering and part replacement this is a job for a technician. Often the video output i.c. fails and on some brands a resistor can open and cause this symptom also. One other possibility, with some TVs however, is that someone turned up the screen control. This control is accessible on some units through the back cover and is a service adjustment. Some units even had the control shaft projecting through the cover. If the screen control is there it usually is labeled along with the focus control. Adjust it until you get normal brightness. If this is not an option or it does not help you will need that technician.
Nov 17, 2009 | RCA Televison & Video
LCD screen went blank
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 22, 2009 | ViewSonic VX2235wm LCD Monitor
Some key are sticking cant type that good as normal, key are sometime hard to push , blow it ot with that stuff in a can
If they are still sticking after blowing the keyboard out you may have spill some form of liquid on it that is causing your problems.
If you are pretty adept you could carefully remove all the key caps and clean it out a little better.
If not you may want to consider taking it to a local repair shop.
Again if you are confident enough then laptop keyboards are not that expensive to replace (probably cheaper than a repair) It is usually a pretty simple task that would take anyone with some common sense about 15 -30 minutes to do.
In the mean time you could always buy a cheap USB or PS2 keyboard and use that (check which type you need)
If this information was useful please click below
Aug 18, 2009 | Compaq Keyboard
Screen on lg shine is distorted
Most likely your screen has either received water/moisture damage, or the screen got bumped pretty hard on something. The LCD is pretty much dead, and can possibly be repaired by your provider. But I would reccomend getting a new phone if possible either via upgrade or purchasing a used one on ebay.
May 24, 2009 | LG Shine CU720 Cellular Phone
Viewsonic vg700b lcd monitor screen turned black
there's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | ViewSonic VG700b 17" LCD Monitor
My viewsonic vg700b turns on but the screen is black
Have you found a solution?
I have the same problem
Apr 01, 2009 | ViewSonic VG700b 17" LCD Monitor
Little white dots on the screen
dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
May 16, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Monitor Colour
for whatever reason you have lost your blue gun. it could be a matter of an adjustment or a defective component in the blue video driver. take it to have it serviced.
Jun 20, 2006 | ViewSonic VG700b 17" LCD Monitor
ViewSonic VG700b 17" LCD Monitor Logo
116 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
