Question about Frigidaire Dishwashers
Frigidaire gallery series dishwasher wont start
Just moved into a place with a dishwasher. I havent run it before. No matter what buttons I press or sequence of buttons I press, the thing just wont run. The lights flash and nothing happens. Could there be a reset or something?
  • 2 more comments
  • shawnhoskins Nov 15, 2008
    I'm hoping I just over looked something simple
  • shawnhoskins Nov 16, 2008
    I just checked the valve under the sink to the dishwasher and it is indeed on. Any other ideas?
  • Terry Rodgers Jr.
    Terry Rodgers Jr. May 11, 2010
    this may sound stupid,but have you made sure the water is turned on to the unit?(usually this valve is located under the sink)alot of times while a property is unoccupied,while trying to rent or sell,they will turn the water off to things such as,dishwashers,icemakers,waterheater,ect (let me know if this helps)thanx for using fix-ya,please rate all replys
  • Anonymous Mar 26, 2014
    Is there a reset code for the dishwasher?
    Scholar:
  • 131 Answers
The only other thing i know to tell you,without knowing more about this problem,is check the float switch in the tub(its under a tall cover,remove this cover & make sure it is'nt stuck in the up position)otherwise it could be anything from the water inlet solinoid,a bad switch,or even the pc board.hope this helps
Posted on Nov 16, 2008
How can I get my Frigidaire Dishwasher 900 series to start?
Sounds like you have a bad door switch. You might also have a motor that tends to freeze or lock up. It could possibly be a bad motor capacitor too. Does this help?
Mar 18, 2015 | Frigidaire Gallery Dishwashers
Power failure
  • Find the "Start/Cancel" button on the dishwasher's control pad. This button is located on the far-right side of the pad on most Frigidaire Gallery dishwasher models.
  • 3 Press the "Start/Cancel" button to clear the "PF" error code. Resume using the dishwasher as normal. You may have to reselect and start your cycle from the beginning.
Dec 02, 2013 | Frigidaire FDB520RH Builtin Dishwasher
My frigidaire gallery series dishwasher wont start and the lights are flashing. whats wrong?
I would cut the power to it for a full 5 minutes and see if it resets itself???????
Feb 10, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
My Frigidaire dryer (Gallery series) will not start. It makes a buzzing noise every time i pres the start button.
This is a indication that the motor had shorted out to ground and everytime you press the start button the start and run windings of the motor are grounding out. You'll need a new motor for this fix.
Dec 14, 2010 | Frigidaire Electric Dryer
Frigidaire gallery prof series dishwasher- arms dont work
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
Does not wash well, does not use dishwashing liquid
Here are a few steps to solve your problem. First of all empty your dishwasher and pour in two cups of vinegar. Run the longest and hottest cycle you have. This will clean your machine.
Always run the hot side of your kitchen sink until the water is as hot as it gets and then start your dishwasher.
Switch over to a tablet as opposed to powder or liquid and just toss the tablet into the machine,
now you should be back up and running.
Aug 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridgidaire Gallery Series Dishwasher Leaks from bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dishwashers Logo
377 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
