Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Can you recommend a he detergent for baby clothes?
My daughter is having a baby in january 2009 and although she loves her cabrio washer,she has called numerous detergent manufacturers and no one seems to have a detergent to recommend for babyclothes.
  • Anonymous Mar 29, 2014
    washer displays an sd fault only using half of recommended he detergent
    President:
  • Whirlpool Master
  • 2,651 Answers
Theer have been no reported problem with using the DREFT baby soap in the HE made machine,
Posted on Nov 16, 2008
How to fix error message SD on our cabrio washer
Check the drain hose for kinks. Then check entire circuit: tub drain>drain hose filter>drain hose pump> drain hose for blocks. The particulars for your model would be in the owners manual or service maual.
Sep 06, 2014 | Whirlpool WTW6400SW Cabrio Washer
Clothes have a white colored residue after wash and parts of the clothes are bone dry.
Allison, We are sorry to hear about your concerns in regards to your Washer. We would recommend balling up the clothing similar to the size of a soccer ball, and place around the agitator one at a time. We would also recommend stacking it up so it's around the sides and the agitator plate is visible with all of the clothing around it. Do not fill up past the 2nd to last row of holes in the basket to help overloading. The bulky cycle will allow more water to enter the tub, but will not spin on the highest spin setting. Since the washer uses less water than a traditional washer it makes it harder for it to remove excess detergent, and it can redeposit on the clothing. Use no more than 2 tablespoons per load, filling all the way to the top row or holes. Make sure the water heater is at 120°F, the best temperature to mix with cold water in. A lower temperature may not make the water hot enough, and the detergent will not dissolve properly. If you need any further assistance after trying these troubleshooting tips, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
5d code
5d is suds warning. The motor is being overworked from too much suds caused by improper measurements or detergent or both.
Cabrio service manual is on my service manual page
Run your washer without detergent a few times. Remember this washer uses less water than a normal washer it has 2 pumps. one recirculates a small amount of water over them clothes. You go adding in a regular amount of clothes and that washer fancy electronics gonna have a cow.
Dec 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
When washing dark clothes in my Cabrio washer they are left with a white residue. I have been using Arm & Hammer HE detergent. Any suggestions? I am not using too much detergent. A friend uses...
Hello harnweys. Definitely switch to another brand of HE detergent, and always choose a liquid as opposed to a powder. Finally, be careful not to overload your machine, set the water level to a higher setting too! Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Can we use powered Dreft Detergent to wash our baby clothes. Have been unable to find liquid detergent for baby clothes. Please respond promptly.
I would highly NOT recommend it. powder likes to clump inside the front loads. I would use a fragrence(SP) free soap if dreft is not available inliquid or h.e. as well be aware most baby detergents are not flame retardent. meaning in case of fire the soap residue left on the clothes naturally do not resist to flames as most detergents do.
Nov 03, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW7600XW on the display screen is says sd and all the lights are blinking
The manual that came with the machine explains that the Sd error means "suds" and that means you are putting way too much detergent in, or aren't using HE detergent. If you keep doing this you're going to damage your machine. These washers are so water efficient, you only have to use about 1/4 to 1/3 the HE detergent the bottle recommends. Suds-lock has been the culprit behind many a HE washer death since their inception. Hope this helps.
Jul 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer not getting clothes clean
hi there,
there are 2 reason for not getting clothes clean:
1) water supply
if you don't have enough incoming water, the clothes will not get clean and you'll have detergent residue left on your clothes
2) detergent
you have to use the He detergent for the best results
Oct 03, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
