Question about Black & Decker B2300 Bread Machine
Paddle stuck inside bread
Every time I cook a loaf of bread the paddles cook inside the loaf. This has happened ever since the first time I used it. Any suggestions how to fix this?
  • 1 more comment
  • katwoman453 Dec 06, 2008
    The bread stuck worse without the paddles in the pan, but thanks for the suggestion.
  • angelamaclea Mar 23, 2009
    i have the same problem with the paddles sticking in the bread i used this twice now thank god i have the reciept this thing is a peice of garbage it is going back..
  • barbmason Apr 18, 2009
    I have only made 2 loaves of bread, and both times when the baked bread was turned out of the bread pan onto a rack, the paddles got lost deep inside the hot, soft bread. It created a significant hole (actually 2) when I tried to retrieve the paddles. I gave up and left them in there, only to be plucked out as I cut slices later. These holes spoil a good portion of the loaf. I'm not impressed.
  • 3 Answers
I have the B2300 bread machine as well and I have encountered the same problem as you. So, I came up with the idea of removing the paddles right after the machine has stopped mixing the dough. Whenever I bake bread at home, I tend to follow the above mentioned solution and it made my life much easier.
Posted on Nov 17, 2008
Kneading paddle bakes into the bread
Kneading paddle on EVERY breadmaker usually bakes into bread. Let the loaf cool and then gently remove it. Or use the dough setting and cook bread in the oven. (i do this) delicious!
Jul 05, 2017 | The Kitchen Appliances - Others
Bread kneader gets stuck in loaf
That is going to happen often with breadmachines, especially when making breads with thick crust. The only way to avoid it 100% of the time is to make dough with your machine and then do the final rising and baking in the oven. There is one other thing you can do to avoid the dreaded" paddle injury" to your loaves and still bake in your machine. Visit me at and I'll reveal my little trick!
Feb 06, 2013 | Kenwood Bread Machine BM350
Kneading paddle gets stuck in loaf after baking and is hard to remove
Hi, it is common for this to happen with bread machines. It often helps if you have a modern machine and you can choose the crust color and you choose Light Crust. The other thing you can do is if you are using recipes that use water in the liquid phase use milk instead. If you paddle still sticks then you just need to turn the loaf on its side and use a popsicle stick, tooth pick etc and trace around the loaf where the paddle is and dig it out.
Aug 09, 2011 | Kitchen Appliances - Others
Bread keeps sticking to paddle. Tears a big chunk of bread out of bottom. Happens all the time. Any solutions, Thanks
You might need a new paddle if cleaning yours doesn't work. It needs its release coating. You could also try making sure the paddle moves smoothly on its shaft. If it hangs up when you pull the loaf out, it'll tear a big hole in the bottom of the loaf. Replacement paddles for most makes can be found on eBay. They run around $15, though, so I'd try cleaning and lubrication with vegetable oil first. Good luck.
Mar 04, 2011 | Oster 5838 ExpressBake Bread Maker
When bread made blade inside loaf happens everytime only used the brand new bread maker 4 times.
Blade left in the bread is normal. Just use a wooden toothpick and push in with it as you outline the paddle with little holes until you can remove it. After a little while you can use your fingers to just pull it out.
Whatever you do don't use anything metal to remove it or you risk damaging the nonstick surface on the paddle!
Dec 05, 2010 | Toastmaster Breadmaker's Hearth 1193 Bread...
Agitator in bread machine is inside of the loaf of bread when the complete cycle is done
That often happens with bread machines and is normal. Just find a toothpick or popsicle stick and push in around the outline of the paddle and extract it from the loaf. Never use anything metal if your paddle has the non-stick finish, that is why you want to use wood or plastic.
Nov 26, 2010 | Kenmore KTR2300 Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Cooked loaf not coming out of the tin
Sounds like the paddle is no longer non stick..
Might be worth changing it.
Feb 12, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Black & Decker B2300 Bread Machine Logo
574 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
