Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
I have a Nuvi 660 that is shutting off after about 40 mins of usage, even after a full charge.  It appears that the battery is not keeping a charge for very long.  Unfortunately, I am out of town and do not have the Garmin charger for my 660.  Can a Motorola phone charger with the USB connection be used effectively to recharge my 660?  When I plug the cell phone charger into the 660, the screen shows that appears resembles a Nuvi with a cord connected to a large box (computer?)
If there is a problem with my battery, I guess I can go to the repair service directory and find a facility that can replace the battery, or is that something that I can do without sending the unit in?
  • Garmin Master
  • 2,130 Answers
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Posted on Nov 17, 2008
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 680 Touch Screen not working
You dont have much option, if the touch screen failos or becomes intermittent then its dying or dead and can only be fixed by a total replacement
Cheaper to buy another GPS
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
My 6 month old Nuvi 760 turns on, but no signal
It is entirely possible you need a new battery. Use and abuse shortens the battery life. Starting the engine while GPS connected or overcharging on AC or PC.
If it fails to acquire on full charge or replaced battery then it has a damaged chip from the usage i stated above. Not warrantble either.
Jun 30, 2009 | Garmin Nuvi 660 GPS Receiver
660, hangs up totally after ca. 40mins use
Hi Martin,
It sounds like a corrupted firmware update. Please go to this site:
http://gpsinformation.org/perry/nuvi/
I believe the latest firmware version for a 660 is v4.7. You can try reflashing the firmware with v4.7 or trying an earlier version. Let me know if this resolves your issue.
Also, the Nuvi can lag if you have large picture files on an inserted SD card.
- Jim
SHARCNET-USA
Feb 13, 2009 | Garmin Nuvi 660 GPS Receiver
Full charge lasts just under 3 hours
The battery life is advertised as THREE to 7 hours. Try reducing the backlight time. You're within factory specifications.
Apr 25, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi-660--garmin
Yes be sure your battery is full charge, go on the GARMIN web site and do an update.
Install the web updater from GARMIN.
If you have a battery low its normal. You did not mentionned into your comments that you had try a charge. I can not assume but i hope you did.
No problem with the battery was reported from GARMIN at this time. Everything is reporting fine by many others users.
Jan 03, 2008 | Garmin Nuvi 660 GPS Receiver
Getting started with new Garmin nuvi660
Plug your 660 with usb into the usb port, computer must not set on sleeping mode (screensaver).
It will take 3-4 hours to be full charge
Dec 18, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Dec 10, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
359 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
