Question about Pioneer AVIC-D3 Car DVD Player
My Avic d3 won't eject
I got this from a friend who got it from a store display, i heard there may be some sort of code to unlock it so it ejects. It doesn't make any sounds or anything when i'm pressing the eject button to make me assume it would be jammed, i'm so confused i just spend 250 to have it installed please help!
thank you!
  • Anonymous Nov 24, 2008
    I had the same exact problem and took to the installer at Best Buy. He was stumped and then looked online and found the correct buttons to push to reset. He would not tell me which buttons but looked like the eject and mute button as listed in another post.
  • jmitchell2 Dec 07, 2008
    I have AVH-P4000DVD and it wont eject the dvd
Try holding the menu and left arrow button at the same time you hit the (little) reset button. As the system reboots hit the eject button a few times. You may need to do this cycle more than once.
Posted on Nov 21, 2008
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
heard.
Jan 26, 2016 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Pioneer avic z1 won't close or eject
You need to take it out take the fuse out the back and reset it wait 30 seconds Then put the fuse back up power back up and it should operate like it supposed to.!!!
Feb 04, 2013 | Car Audio & Video
Check engine light comes on flashes 3 times
first you have to diagnose the cause of trouble.
How to get the codes on a 1998-1999 Dakota: Depress the trip reset and trip/odometer switches, and, while holding them, turn the ignition to ON/RUN, and wait about 5 seconds. This sends the car through a short self-test sequence that lights all segments of the odometer and shift selector read-out (where applicable). It will then display the stored error codes.
If that doesn't work, try holding in the trip/odometer button while doing the key on/off cycle 3 time. If that doesn't work, some people have reported success by doing the key on/off cycle 10 times instead of 3.
you are unable to pull the trouble codes yourself, wether it be because you aren't doing the procedure right or perhaps your truck doesn't have that feature, most auto parts stores have scanners and will pull your trouble codes for free. I know for sure that Autozone does this, and have heard that many others do as well. (They do this for free because they are hoping that if it turns out to be a bad oxygen sensor, for example, that you will purchase an oxygen sensor from them.) You can also purchase a scanner of your own;
Dec 08, 2011 | 1998 Dodge Dakota
I have a pioneer avic d3, and it is asking for pets name...and wont let me into the unit...
You or the person before you has locked the unit. You may have to reset the unit. The reset button is located to the right of the eject button. You will need to use a needle or pen.
Apr 24, 2010 | Pioneer AVIC-D3 Car DVD Player
My avic x1 have no screen light buttons donts work apart from the eject button tryd new ribbon any other ideas please
i am having the same problem.... the only button working is the eject button, theres no sound and no screen display although the facia lights are on.. help!!!
Feb 20, 2010 | Pioneer GPS AVIC-X1 car radio
Battery went dead on my car and i need the master unlock for my avic-d3
Have you tried calling Pioneer and giving them the serial number? They should have at least something on file for a master lock code. It wouldnt make sense if they did not since we all lose important documents.
Oct 15, 2009 | Pioneer AVIC-D3 Car DVD Player
Pioneer AVIC-D3 Car DVD Player Logo
464 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
