Question about Panasonic TC-21PM10RQ 21" TV
TV Tuner Locked
Hi
I bought Panasonic TC-21PM10RQ 21" TV it was being used in an xbox display and the TV tuner is locked so i cannot use it as a TV is ther an unlock code or a way of entering maintence mode or something?
Phil
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Does the Panasonic TV Model
CNET.com does product reviews on TV set. The specs from the site says your 26" 720p TV has only an analog tuner. Hope that helps.
Posted on Jan 19, 2009
  • 30 Answers
SOURCE: Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Posted on Mar 24, 2008
  • 356 Answers
SOURCE: Does the Panasonic TV Model TC-26lx50 have a digital tuner?
Hi mrfeld, The TC-26x50 has only an analog tuner, if you want to recieve the new broadcast OTA signals you will need a Set Top Box. Let me know if you need further explanation and please rate this solution. LOne99star
Posted on Jan 16, 2009
  • 277 Answers
SOURCE: hi have recently bought secondhand panasonic CRT
power supply faulty
Posted on Jan 19, 2010
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
First tv no sound i open his eprom ic leter open ic i saw vertical line
Please don't play with this set. Get it repaired by its authorised service center. It will be best to throw it away, rather than making any repair to it, without proper experience and knowledge. You never going to get this set right by no way hereafter.
May 07, 2012 | Panasonic TC-21PM10RQ 21" TV
I have a CRT tv and the picture is just a thin band in the centre of the picture tube. The sound is ok
That is called "Frame Collapse" because the picture "Frame" has collapsed into the single horizontal line.
It may be caused by dry joints or output failure of the frame output stage.
A fairly inexpensive repair.
Mar 03, 2011 | Panasonic TC-21PM10RQ 21" TV
Loss of vertical sweep
Hello
Your TVs vertical output Ic may be damaged. You just open your TV and locate the vertical section inside, usually panasonic uses Ic numbered [LA7837] which will be marked as part number IC451 on the circuit board. It is a 13 pin Ic, sometimes the number may be different in your TV, as Panasonic uses four types of LA series Ics in their sets. I think that you have some knowledge in the service field, so the complaint states only "loss of vertical sweep", and so I'm not going too deep into description. OK.
Nov 06, 2010 | Panasonic TC-21PM10RQ 21" TV
Mistakely locked my TV(4 system CATV HYPER-BAND TC-2101T)
my TV locked, but the password had not been activated. what can i do
Aug 19, 2009 | Panasonic TC-14KM30R 14" TV
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Tuner
Tuner is integral part of mother board,repair only.Shorted IC ?
Detailed,miniature soldering will be needed-want to pursue??
send me service number on back.....T.
Oct 25, 2007 | RCA F27690BC 27" TV
CHANGE CHANNEL
TRY manually if it does not help your problem 1 remote contacts. 2 remote. 3 problem in tuner 4 problem in system control circuit relating to tuner.
Sep 26, 2007 | Televison & Video
Panasonic TC-21PM10RQ 21" TV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
