Question about GE JVM1660 Microwave Oven
GE Spacesaver Microwave kicked out, will not come on or reset.
Model # JVM1653WDOO4
SERIAL # TD950057S
MANUFACTURED OCTOBER 2002
Microwave has been kicking out over the last couple weeks, then coming back on, having to reset the clock, etc. I replaced the fuse once about a week ago and it seemed to work, but now has kicked out and replacing the fuse did no good. Have turned the circuit breaker on & off with no result.
    President:
  • 2,712 Answers
Looks like a circuitry/power issue. Difficult to say without actually inspecting the unit. Best bet would be the control board is fried. If you know how to repair a micrawave, try the following:
Test for power going to board. If exists, problem lies on board somewhere. On the GE/Hotpoints using the "smartboard," it is sometimes possible to locate a bad soldering connection on the board that can be repaired, restoring function to the board. Otherwise the entire board must be replaced.
However, if you do not have experience, I would definitely recommend getting it serviced instead (or buy a new unit, whichever is cheaper), as there is capacitor that holds 2000V even when unplugged. There is a specific procedure to discharge this capacitor, and it would be life-threatening to do so if you have no prior experience.
Posted on Nov 17, 2008
    Scholar:
  • 181 Answers
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
  • 5 more comments
  • fixyy Nov 17, 2008
    Q - My microwave is running and sounds like it is working but will not heat up anything.
    A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
    Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
    Q - My microwave went dead when I opened the door ( same problem as closed the door ).
    A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
    Q - My microwave is completely dead.
    A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
    Q - My microwave blows the fuse inside itself as soon as I push the start button.
    A - Usually a shorted high voltage capacitor...see components section.
    Microwave stopped working while cooking. Replaced a 20AMP fuse.
    When the cook cycle starts, microwave makes a groaning noise and stops. It loses power since the fuse is blown.
    Solution: High-voltage capacitor shorted. Replaced it and microwave works fine.
    Its located behind the fan underneath the high-voltage transformer.
    Remove the vent fan hood
    Remove the display control panel by removing the screw
    Take pictures of all the connections behind the control panel.
    Unhook all connections
    Remove the connections to fan
    Remove the fan
    Remove the screws and connections for interlocking switches.
    Make sure the high voltage capacitor is discharged!
    Remove the high voltage capacitor and replace
    Retrace the steps and put everything back.
    Q - I burnt something in my microwave and now it is dead...help!
    A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
    Genius:
  • 1,550 Answers
This is usually due to a defective magnetron causing electrical interference .
Also chance of malfunctioning of the circuit board .
GE Spacemaker XL4100 Model # JVM1450WA has stopped heating
If no fan, check the door switches. If it sounds like it is working then the ma
Dec 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need a manual for a GE turntable microwave oven, manufactured in March 2002, model # JES636WD001.
Go to geappliances.com and click on the "Service and Support" link. Under the drop down menu, locate "Owner's Manuals and Installation Instructions". Type in your model number and your Owner's Manual is available in .pdf (Adobe) format. Save a copy to your PC, or print one out.
NOTE: Before you ask...Although your microwave carries the GE logo, it is manufactured by Hotpoint.
I hope this helps you.
Jul 23, 2009 | Microwave Ovens
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
Where is serial number located on GE Spacesaver?
If you open door and look at upper edge of cabinet it should be there.
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1660 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
