Question about Asound (NET-AL100-R2) (NETAL100R2) Network Adapter
Internet connection hi, i recently installed xp and cant connect to the internet through my asound ethernet card to cable set top box lan line.have re-booted didnt work.have checked network driver properties which says it is working properly but when i go into properties it doesnt have a network address is this the problem if so what address goes in there. have tried connect wizard which said contact sp [virgin] who said driver was corrupt but device manager says its working can you help please ..
    Problem Solver:
  • 17 Answers
Try uninstalling the driver and software for the card and restart, upon boot up it should automatically find new device (ie the asound card) and proceed with installing the driver again. JUST IN CASE MAKE SURE YOU KNOW THE MODEL NUMBER FOR THE CARD SO IF THE DRIVER IS NOT UPDATED AUTOMATICALLY YOU WE CAN FURTHER ASSIST YOU IN FINDING THE CORRECT DRIVER FOR THAT PARTICULAR CARD. after reinstalling reboot again.
Posted on Nov 15, 2008
Hello i just format my old lab top thorhiba p200 16b and instaled a windows xp profersional fully updated but i cant connect to the internet i get no intenet gaetway and if i connet a lan cable i get...
go to"my network place" then "view all connections"...den see whether "local area connection" is appearing or nt....if nt dat means u dont ve LAN settings......so 1st get lan . den u will be able to explore de net. for more info see dis... http://www.youtube.com/watch?v=o-kKksYKHR8&feature=related
Mar 18, 2011 | Computers & Internet
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Stopped connecting to internet through land line
hi there, i had kind a same problem with u, the only difference is mine shows "connected" but i can't surf the internet when others in my network are doing just fine. 1st i tried to uninstall my LAN card driver and the reinstall it back. It worked, i can surf the internet but only for a few minutes. So i installed a firewall, in my case, i installed windows defender. After reinstalling my LAN card driver, i realized an unknown program tried to change some of my LAN driver files, so i denied the program access using windows defender. The problem solved !! Maybe it's a virus or spyware, i don't know because before installing windows defender, my avg and antispyware don't detect any virus/spyware. Hope this help, gud luck
Sep 26, 2008 | Acer Aspire 9300 Notebook
Enthernet connection
Ethernet connection is a LAN or a CAT cable
One end of that cable will connect at the back of ur router box that u will have with u or u will get it from ur ISP .
and the other end of that cable goes to the back of ur pc in the jack which says LAN or try to plug it in any socket which fits properly.
u will a light that will start flashing at the back of ur back when u plug that cable in
to check whether u system supports ethernet connection or not
1. right click on my computer
2. goto properties
3. goto hardware
4. goto device manager
5. u will find network adapters there
click on the plus sign on the left side of network adapters
plus sign will change to minus
under network adapters look for an ethernet adapter or network controller
or 10/100 or 10/1000 fast ethernet NIC ( network interface card )
if u have one , then ur pc supports ethernet connection
U just have to connect the ethernet cabel to ur router box and at the back of ur pc and u just have to open internet explorer and ur internet would start working...
if u dont have ethernet cable with u or ur system does not have an ether net socket in ur system , u can goto any computer shop and get an ethernet cable and a socket for ur system
If u dont want to do that , u can go for a USB cable connection with ur pc or a wireless connection....
reply back if u face any further problems
Feb 19, 2008 | Computers & Internet
Problems with IP address
Possible three (3) solutions:
1. Purchase and install a PCI LAN card (NIC) inside your "old tower". Should not be that difficult using any available PCI slot. Most would be auto detect/install by Windows (XP) or should come with a driver CD;
2. Use a USB to Ethernet adapter/converter; and/or
3. Use static IP address for the tower Same IP add (+1 on the last digit, same Subnet Mask, Default Gateway and DNS (if any). Should you need additional information on this method you need to post back details of your modem (brand/model, normally in a sticker underneath) so we can determine if it will allow simultaneous connection on USB & LAN.
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
Dlink dkt-110 wireless router
All right, according to your question, i'll asssume your pc running with win xp..first connect the wireless card to the computer and restart it, the card should be detected, you should get a found new hardware screen then insert the cd and continue installation..if you do not get the screen check in a diff pc if you stillk do not get the message.. the problem is with the pc card or else with the pc where you are trying to install the card/..
Dec 04, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Asound (NET-AL100-R2) (NETAL100R2) Network Adapter Logo
63 people viewed this question
Top Asound Computers & Internet Experts
David Payne
David Payne
Are you an Asound Computer and Internet Expert? Answer questions, earn points and help others
