Question about Logitech X-240 Computer Speakers
Computer announces ''Jack is unplugged'' when the computer is
Idle for a while When I walk away from computer for a while and then come back to start using it again, the Realtek Audio manager shows a " a jack has been unplugged" bubble even though nothing has been touched.
To listen to any music or hear computer sounds for incoming email or anything sound related I have to reboot the system.
I do have my computer on a power savings setting after an hour of inactivity to save energy. Would his be causing it?
  • tazman_30 Nov 21, 2008
    Hi Coss71
    I removed all of the "energy" savings sttings but without success. The "a jack has been unplugged" bublle popped up after the computer sat idle for a while.
    I could not locate the ports settings option you described. Any idea?
    Still open to suggestions.
    Thanks
    Genius:
  • 1,056 Answers
Yes, that very well can be causing the problem.
There are a number of ports that have individual power settings. If you look at them it will have the option "allow computer to turn this device off to save power"
Saving power is great for a laptop running on batteries, but not really necessary on a desktop PC that is plugged in.
Yes you will save a little power (so it can be a "green" thing to do) but you are not going to make a noticable difference in your power bill.
To test this, turn off all of your power savings settings (such as system standby after so long, hibernate etc) and see what the speakers do.
In all my years of doing computers, I have had more problems with systems "re-awakening" then I save by reducing power comsumption.
Posted on Nov 15, 2008
  • Coss Nov 25, 2008
    Go into Device manager (right click My Computer, Properties, Computer Hardware, Device Manager).
    In here you can see each device. You may have to expand the device tree to get to the specific part. Once there, right click, or double click the device to get to the details. If a device has a seperate power setting, you will usually see it on the right most tab. It will say power management. In here, you'll see the setting for allowing the computer to manager the power to that device, take the check off, Apply and OK.
    Hope this helps. Let me know what you find. I know chasing power settings can be a real hair puller.
My magic jack phone stopped ringing and the handset says no line
It sounds like the magic jack is not getting power. Is it plugged into the computer, or a wall outlet? Is the blue light on?
If it is plugged into a computer then unplug the Magic Jack and reboot the computer wait until it reloads and then plug the Magic Jack into a different USB port.
If it is plugged into the wall, Then unplug it for 5 min and then plug it back in.
If it doesn't come up and it is still covered by Magic Jack open up a chat with them at the link here. http://www.magicjack.com/contact.html
Sep 17, 2017 | Lands Phones
How do I turn off male voice that announces everything I type and do on the computer?
command and f5 should turn it off. or go into preferences and accessibility to turn it off
Dec 31, 2015 | Apple iMac Computers & Internet
I just had a starter replaced on my 2001 Nissan Maxima and now it makes a noise like an electric motor is still running but when I remove the ENG CONT 2 fuse,it stops,what could this noise possibly be
Unplug the IAC. Does the noise go away? If so you probably have a bad PCM (computer) and IAC. Possibly bad wiring to IAC. IF noise does not go away unplug starter, does noise go away?
Jun 27, 2014 | 2001 Nissan Maxima
Monitor and keyboard not working
Maybe overheating ? Needs cleaning !
Or maybe it is graphic card... you must see with your servicer.
I can give you this :
turn off laptop, unplug adapter , remove battery, then hold the start key for about 20 sec. and release, turn back computer ion and see if this is the case...
If not :
take it to computer servicer
Mar 06, 2014 | HP Compaq Presario SR1115CL PC Desktop
I need to free up slots because pc has been reset and fix it was removed
Unplug the computer from the line connection, pick it up with both hands, carry it to the storage area and put it down on the floor. Walk away, close the door, and return to the computer you are now using. See wan't that easy.
Dec 28, 2013 | Avanquest Fix-It Utilities 8 Professional:...
My computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Apr 07, 2012 | NTI Backup Now EZ
When I try to start io my netbook, it sounds as if the disk is going, like it does when it starts up normally, but the green processing light doesn light up and it starts to sounds as if the disk is...
1. turn off your netbook completely.
2. unplug the ac adapter and remove the battery
3. press the power button for about 5-10 secs
4. plug in the ac without the battery and turn on the system
-if still doesnt work unplug the power cable and press the power button for 5-10 secs
5. turn the netbook upside down
6. locate the memory door and reseat the memory
-make sure that the memory is properly installed from the slot
then put back the memory door and all the screw
7. restart the computer
Sep 06, 2010 | Acer Aspire One PC Notebook
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
Static on answering tape
I had been battling this one too...your phone may be plugged in too close to a computer where the modem signal can get crossed with your phone line...I read on here that this was a DSL prob but is also appears to be a wireless/cable issue too. If you can move your phone b/c of jack placement/power outlet, unplug the phone at the phone line and power supply, then plug them back in. This worked for me......
Jan 29, 2009 | Vtech Lands Phones
5.1 GMX ProMedia Issue
The jacks on the back are probably for an amplifier output and you probably have had the speaker wire stripped too long possibly shorting out the amplifier as this is a common problem, if not stripped too long it may have just failed, also you need to check by unplugging from back of computer and hook up to a walk man or something with a headphone jack, see if still dead, might also be the cable from the computer to the speakers. Good luck. :-)
Jul 06, 2007 | HP ProMedia Computer Speakers
Logitech X-240 Computer Speakers Logo
1,411 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
