Question about Crane & Co Crane Plumbing 2430W Whirlpool Bathtub, White
Perfume bottle down the toilet
Hi
I accidently dropped a glass perfume bottle down the toilet and it disappeared. It is round and about the size of an extra large egg. Is it going to go on down the sewer pipe or hang ujp in the plumbing under my house?
  • mislis8200 Nov 29, 2008
    I have a couple pf perfume bottles, which have lost the top sprayer after being dropped on the floor I absolutly adore the fragrances so it is very hard to throw them away without trying to fix them if I can. Is there some way to solve this issue?
    Champion:
  • 203 Answers
Put a big hand ful of loo paper paper down and flush if it disappears the bend is clear. you can also lift the inspection cover outside while doing this and see what is happening there although i it is shaped like an egg it should just keep moving . some people leave more than an egg sized load behind and dont have a problem LOL . hope this helps joe
Posted on Nov 22, 2008
Betsey johnson perfume spray broke
1. Look at the tip of the nozzle to ensure that it is still intact. If there seems to be a perfume buildup within the tip, simply run the tip under hot water and use a pin to pry any gunk loose. Press the nozzle tip gently down on the top of the perfume bottle to reattach.
2. Remove the tip of the nozzle if it will not spray and soak a cotton ball with rubbing alcohol. Apply the alcohol to the interior top of the plastic tube and let it sit for 10 to 15 seconds. Use a pin to slide down the center of the tube to remove any built-up gunk that may exist in the tube. This tube is what feeds the perfume from the bottle, to the tip.
3. Use tweezers to pull the plastic tube upward if it will not connect to the nozzle of the tip properly. The tip should snap onto the plastic tube; however, if it does not then the tube is too low in the bottle.
4. Return to the store, where you bought the perfume, and request a new replacement tip. Craft stores may also carry the replacement tips. The sprayer inside the tip may be off or uneven which will cause the perfume not to spray.
5. Exchange the perfume for a new bottle at the store. Manufacturers, especially if it is a new bottle, will replace the bottle at no charge. Depending on the store, you may be able to exchange the bottle even if it is almost empty.
6. Pry out the inner workings of the perfume bottle and dab the perfume on your skin, instead of spraying.Take the insides of the nozzle out by removing the tip, and use tweezers to remove the inner tube. Around the edge of the perfume bottle is a plastic encasement that will need to come off. Use a pocket or paring knife to loosen the edges around the encasement and pop it off. Under the encasement will be a metal ring that attaches the encasement to the bottle. Using the same method as the encasement, pry the metal ring off the bottle. Purchase a small cork to insert in the bottle to prevent a spill.
Aug 05, 2012 | Betsey Johnson 3.4oz Eau De Perfume Spray...
How do you change the font size on the computer?
@mychelemyche
Try the following:
For Windows XP
1. On the Desktop, right click on an empty space and select Properties.
2. A Display Properties window will open, click on the Appearance tab and on the Font size drop-down, choose Large Fonts or Extra Large and click Apply.
For Windows Vista.
1. On the Desktop, right click on an empty space and select Personalize.
2. Click on Adjust Font Size (DPI)
3. Choose Large Scale (120 DPI) or Custom DPI (if you want bigger font)
For Windows 7
1. On the Desktop, right click on an empty space and select Personalize, then click on Display.
2. Choose Medium or Set Custom Text Size (DPI) if you want bigger font.
Sep 07, 2011 | Computers & Internet
There is no perfume coming out from the atomizer
Make sure your that part of your atomizer that is inside the bottle is not broken. You can open the bottle and try it with water if it works. Other problem could be the nozzle. If it's not working you have to go to the store where they sell this fragrance and ask for a new atomizer( no charge) or exchange if your bottle is still full.
Nov 28, 2010 | Britney Spears Beauty Curious Britany...
Which is the world's most expensive men's perfume?
The worlds most expensive Men's perfume is made by Clive Christensen and it comes in a Crystal Baccarat bottle with a 5 carat diamond around the upper portion of the bottle, that retails for $250,000 it comes in both Mens and Womens versions. If you want it in a 1.5oz crystal bottle it will cost you only 2,500.00, or if you want it in a glass gold painted bottle it will cost you around only $750
Nov 23, 2010 | Health & Beauty
What are the top 10 women perfumes of 2010?
Hi, this is very subjective question. Anyway, I'm willing to try..:) #1
At number 1, the Lovely Perfume, from *** and the City's Sarah Jessica Parker is what we are putting at number 1.
#2
At #2, I'm including the Armani Code Pour Femme. This is a top selling fragrance, and is slightly more expensive than Lovely. It is a fragrance that is sure to leave a lasting impression on the wearer. It has a nice bottle, and the fragrance has notes of interesting ingredients, such as orange, ginger, sandalwood, and even honey! It is truly a sexy and sophisticated perfume, perfect for mom or sister.
#3
They say that diamonds are forever, and they truly are! At #3, we place the Armani Diamonds. This is truly a sensual and alluring aroma. If you are glamorous, you need this!
#4
At #4, the Calvin Klein Euphoria holds the position. This is a fragrance that makes all the difference, and is truly luxurious and a stunningly versatile scent.
#5
At #5, we have the popular Calvin Klein Eternity. This is a nice fragrance, which is better for the mature lady. Try this amazing combination of wild potent flowers, and delicate fruit.
#6
Diesel's Fuel for Life takes the number 6 position. This has a nice bottle, and is also a powerfully pretty perfume. A nice Christmas present for the woman in her 20's.
#7
Vera **** Flower Princess holds the #7 position. This is a nice bright pink heart-shaped bottle, and looks great on any dresser. This is a sweet and fruity floral fragrance.
#8
Elle Perfume is at 8, and Yves St Laurent's latest women's scent, 'Elle'. If you have a best friend, this is the fragrance to get them.
#9
At 9, we have Opium Perfume, and again, this is made by Yves St Laurent. This is a best seller. It has been around since 1977, so holds a good position since it was released. Though it still holds a good position.
#10
Kenzo Flower Perfume hits 10, and is a great Japanese item. It delivers as a strong and pure fragrance, that you will remember. It is an all round winner.
Change font size in windows XP
See if this is what you are looking for. Right click on your desktop. Go to Properties. Then go to Appearance. At the bottom you will see a drop down menu where you can choose normal, large, or extra large Font Size..
Sep 20, 2010 | Microsoft Windows XP Professional SP3 Full...
Text msg font size suddenly extra large, how to reduce size
use the volume key and act like your turning the volume down and the text size will go down.
Jan 31, 2010 | Samsung SGH-A877 Impression Cell Phone
Crane & Co Crane Plumbing 2430W Whirlpool Bathtub, White Logo
645 people viewed this question
Top Crane & Co Home Experts
bwbconstruct
Level 1 Expert
Dan
Level 1 Expert
bobalix
Are you a Crane & Co Home Expert? Answer questions, earn points and help others
