Question about Amana ACS3350 Gas Kitchen Range
Model ACS3350 oven stops heating up mid cycle
My oven stops heating up. After the oven cools off I have to reset the control panel and start it again. When the oven stops working the control panel does not display anything.
  • 3 Answers
Does your range ever get very very hot on the exterior, mostly by the control panels?
Posted on Aug 21, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Amana ACS3350 Control Units shuts down when over heats up
Sounds like a bad safety valve Test for 3.2-3.6 volts AC at the gas safety valve with the igniter turned on. If the voltage is there, you have a bad safety valve. If the voltage is low, you have a weak igniter and the igniter will need to be replaced. You can test this with a multi-meter.
Post back your results.
Nov 27, 2012 | Amana ACS3350 Gas Kitchen Range
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 | Ovens
When the oven has been on for a while, the computer panel heats up and turns off. I have had the oven door adjusted but still have the problem. Too much heat is escaping from the oven door. The burners...
I once had this on a kitchen aid that there was a fan inside meant to cool off the circuit board and it had died resulting in the extra heat hitting the main board. maybe check if there is a fan that circulates the air around that. As I recall it pulled air in right above the door so that it could cool the computer
Dec 16, 2010 | Amana ACS3350 Gas Kitchen Range
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Amana ACS3350 Gas Kitchen Range Logo
252 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
