FixYa.com
Tags:
Saeco Magic De Luxe Espresso Machine
Temperature problem, Saeco Magic De Luxe
By 2Pansy - usenet poster
My Saeco Magic De Luxe (actually, an Estro Magic Profi, but I think it's
the same machine) produces espresso that's not as hot as I'd like it to
be.  It's more than warm, but certainly not hot.  Is there an adjustment
that controls the boiler temperature?  Is something out of whack?  Any
suggestions would be appreciated.
By the way, I'm also not getting the steam pressure that I'd like from
the frothing arm -- could this be connected?
Thanks!
Roger
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 07, 2005
Thanks for Trying (70)
Joey2
Joey2 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Possibly time to use that coffee machine cleaner that smell like lemon... It
should with repeated applications, clear the scale off of your heating
elements and increase their performance, as noted by more steam pressure,
and hotter espresso, though the thermostat should be what controls the water
temp thru the coffee puck. Are you able to preheat the grip prior to making
your shot? That may help. And preheating your cup also. That exhausts my
knowledge.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 23, 2007
Not Rated (0)
JohnnyBeans
Rank:Wiz Wiz
Rating: 83%, 63 votes
I agree with Joey above, but there may be a way to increase your temperature. Some magic deluxes came with a resistor on the temp sensor. If yours has that, you can cut it off.
Given that this solution would require you to take the machine apart.
Espresso Machines sales, service and Cleaning supplies.
www.cerinicoffee.com
Comment by JohnnyBeans, posted on Nov 23, 2007
It will increase your coffee a few degrees which make a difference.
Can you Help with these Coffee and Espresso Makers problems?
The far left light
Hi, The far left light on my... Answer This...
need replacement gasketor seal...
need replacement gasketor seal... Answer This...
I just bought a Krups
I just bought a Krups machine... Answer This...
Stops Mid Brew Cycle - Saeco...
Just stops brewing when the... Answer This...
The Coffee isn´t strong...
I had my machine serviced and... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
