Printers
Problem for Printers
Generic problem for all Printers
MFC-665CW Scanner keeps saying Con...
By pazmino5 on Nov 15, 2008
I have a Brother MFC-665W. It is on a LAN using DHCP. I want to scan, and when i pushed the Scan button the LCD on the printer says "Check Connection". I can print to the printer, copy, and fax from it, but it doesn't want to scan. I've tried to scan from a PC using the Control Center 3, but when i try a prescan it gives me a Failed to Connect to device message. I've also tried setting static and clearing memory from unplugging the power, while press and hold the red stop button turned plugged back the power, but still the same have the same issue.
Clarification Request
Posted by seekandfind on Mar 07, 2009
I mean it says check connection to be exact
Same Problem
Mar 07, 2009
-   I have the same problem. I used to be able to use the scan button to scan and now it says connection failed. It doesn't matter if I shut firewalls off or not.
Has anyone solved this problem? Please post back here.-   seekandfind
Feb 28, 2009
-   I have the same problem. I can'tt believe I cannot find a simple solution to this problem. -   Guest
Jan 14, 2009
-   I wish I had never bought this! THe pictures print terrible, too-   finkj
Jan 11, 2009
-   Same problem here. I have scanned in the past but now it will not let me, giving me the error message "CHECK CONNECTION." -   moreton197
Dec 25, 2008
-   Yep it's hard to scan over the network, or even to a local storage like memory card-   Guest
Best Solution
posted on Apr 16, 2009
Helpful)
tmbrye
Rank: Apprentice
Rating: 92%, 6 votes
I have a brother mfc-490cw and was having this same troubling issue. I have mine connected with the LAN. What I did to get it working again was press the MENU button. Then I went under the NETWORK item. On my machine there is a factory reset choice. I selected YES to the factory reset and then also selected YES to rebooting and when it came back up I was once again able to SCAN.
Hope this can fix your issue.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Apr 19, 2009
Somewhat Helpful)
jim0115
Rank: Apprentice
Rating: 75%, 1 votes
I used to be able to scan without issue, but experienced this same problem today. The printer showed as offline in my system tray even though it was not. I checked the Brother support site and saw that there was a new firmware update issued on 3/26/09, so I downloaded the update and installed it.
During the process, the printer beeped repeatedly as the firmware update was happening, and at the end of the update the system tray suddenly showed that the printer was now online. I can now scan from the Control Center, though as of right now if I try to scan by pushing the scan button on the printer itself I am still getting the "Check Connection" message.
So, it's not completely fixed but I am able to scan without issue from the Control Center interface.
Was this helpful?
Yes
No
Solution #3
posted on Sep 11, 2009
Not Rated)
staceyde
Rank: Apprentice
Rating: 0%, 0 votes
Make sure you IP address in the printer settings matches the IP address with the settings in your computer. If you hit (on the actual printer)
Menu using the arrow keys go down to LAN hit OK with the arrows keys go down to WLAN (for wireless) hit OK (TCIP should be highlighted )hit OK again You will see the IP address...copy it down somewhere
THen go into your computer Control Panel Printers/faxes double click on printers and faxes find Brother printer Right click and select properties Select ports CONFIGURE your PORT name OR IP address slot should match the one you took of the printer. CLick ok...
that should work...Hope it helps someone!
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
Is c4200 stil availabl eto buy?
Answer
where is service centre in Delhi-110092
Answer
I am trying to print and the computer is saying my documents are pending in the queue how do I... (More)
Answer
it prints blue instead of green when i print. anything that should be green turns out totally... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 30, 2008
same issue--"failed connection" Augh!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
