Question about Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit
Replaced leaking trigger valve wit new valve kit.
Nail gun will not shoot nails .
cleaned all parts in gun and replaced all o-rings with stanley bostitsh parts.
    President:
  • Stanley Master
  • 1,388 Answers
I have seen many small bostitch guns all with different problems that did not shoot nails. Both of your guns have simillar triggers. You might try the trigger valve from the gun that works to see if that is the problem. Most no fire situations come from faulty trigger valve. The trigger valve used in your guns has a part that stays in the body of the gun; be sure to replace both parts. If still no fire check the following:
Remove the head and check if the piston/driver travels all the way down the cylinder with the tip of be blade showing at the nose. Some piston/drivers have a grove that must be aligned.
Check that the headvalve travels into the head and returns. Push the valve in with your thumb then cover the small vent hole at the base of the head where the gasket sits with your finger and release your thumb. The headvalve should be held in with vacuum then pop up when you remove your finger from the vent hole. If the headvalve does not stay pushed in with the vent covered, the orings are leaking and can cause the gun not to fire. Try lubing the headvalve with light grease such as silicone lube. Do not use bearing grease. Silicone lube is available in small amounts at plumbing supply/lumber outlets such as Lowes. It looks like wax feels like shortening.
Reassemble the gun and check your work. I test the gun with-out nails and without the trigger installed. Just place the nose of the gun on a piece of rubber, (I use a piece of heavy garden hose rolled up tightly into a coil) and press the trigger valve pin with your finger. The reason that I leave the trigger off is that sometimes the problem is caused by the safety mech not pushing the trigger pin correctly. enjoy
Posted on Nov 29, 2008
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
I have an F60FN Stanley Finish Nail Gun.
did you lubricate the o-rings before reassembly with a dab of grease? also does the tool fire at all, could be a problem with the firing valve. Let me know what you find and I will keep trying to help
Jan 05, 2012 | Stanley Air Tools & Compressors
Leaking air through trigger area. Will not nail at all.
The trigger valve has seven orings. The oring kit may not include all orings needed. To replace the trigger valve, remove nails, remove the rollpin holding the trigger with 3mm driver to expose the trigger valve. Next remove one or two roll pins holding the trigger valve in the body of the gun. Apply air pressure to gun and catch the valve with gloved hand (use caution because the valve may come out with force). Note the position of the valve in the body of the gun in relation to the roll pins. If the firing pin seems loose in the body of the valve, replace the whole valve(could be # tva6 cost about 20 dollars on ebay). Good luck
Aug 23, 2011 | Stanley Bostitch N80s Nailer -rebuild...
I have a N-60 finish nail gun. It is leaking from the trigger and it is trying to fire a nail and discharges the rod to drive the nails and the rod stops and will not retract. I think I need to purchase...
the trigger valve could be causing a lot of your problems, you are correct in ordering the o rings and trigger valve, make sure to lightly coat the o rings before installl. If you have trouble with the valve I have detailed instructions in the TIP section on how to remove safely.
Aug 15, 2011 | Stanley Bostitch Nail Gun
How do you fix/repair 15 guage nail gun o-ring for the nail gun triger. air is leaking from the triger
the trigger assembly would need replaced. I have detailed instructions in the tip section on the removal and installation of the trigger valve. Let me know if you still need more assistance.
Jul 07, 2011 | Stanley Bostitch Nail Gun
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
I have some air nailers and staplers that have some leaks and aren't working properly. I would like to try rebuilding them, they are bostitch, paslode, and senco. I have found the rebuild kits for trigger...
The kits for the senco guns, have all the o-rings and seals needed to stop most leaks, no hard parts. You have to replace all of them, no oil is needed, but it needs to be clean, some have little tubes of grease for the o-rings. I'm sure the other guns are the same way. Some of them will give you a fit. I had a senco sfn1, totally rebuilt, still leaked, tried it again, still leaked, called senco, they said send it to us, they fixed it for free, but never said what the problem was. Some times the triggers go and you end up building the whole gun for nothing, and the trigger still leaks, they are the toughest to spot. I have seen a lot of complaints about paslode. We tried them all in our shop, and the senco was/is the best, So we fazed out all the other guns and kept the senco, so all the nails were from 1 dealer, all the parts, we weren't looking all over town for a box of staples.
Feb 23, 2010 | Stanley Air Tools & Compressors
The driver is not going back up after shooting nail.bostich coil framer
The gun needs to be rebuilt. The seals, diaphragms, and valves need replacement. Do a search on the internet for Stanley Nail Gun rebuilding kits. Simple job to do. I did mind last year for under 15 dollars I think. Make sure you replace all the parts including the "O"-rings.
Jul 21, 2009 | Stanley Air Tools & Compressors
Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit Logo
457 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
