Hi I have tried all the codes I have in the book but none are working, I can get my samsungs tv to work and my phillips dvd player but not the goodmans please help
Try Code Search Method.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
SOURCE: phillips pm3s lost code book:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: program code into a Phillips remote for a Sanyo TV
need the code for a sanyo tv 19 ince mode ds19330
SOURCE: Total Control 4 wont work my freeview box
im looking for sagem freeview code on total control.
thank you
SOURCE: remote control codes for freeview and dvd recorder
the codes that came with my one for all 6 dont match the bush free view box, any 1 know any more or where i can get them please.
