Question about GE GDS18LBR Bottom Freezer Refrigerator
Need to replace evaporator fan GE profile performance TNX model
I think my fridge's evaporator fan just ground to a halt (at least that's what it sounded like), but I can't see how to actually get to it to replace it----can anyone help?
Unfortunately, the evaporator fan has probably frozen in water trapped in the defrost drain. This seems to be a common problem with these GE bottom freezer models. You can shut it off for 12-14 hours and leave the doors open and it will thaw and drain into the freezer compartment. But you probably have food that you would need to put into another refridgerator to do this. Another option is to take out the bottom liner of the refridgerator to do this - I had a service man do it the first time it happened - he then used hot water and a hair drier to get rid of the ice that was stopping the fan. Unfortunately, it seems once this problem starts happening, it will continue to reoccur and I have not found a long term solution yet
Posted on Apr 08, 2009
    Problem Solver:
  • 5 Answers
Jaalbregtse's solution is incomplete, after taking out the drawers, floor and bottom insulation of the fridge to expose the fan you must clear out all of the ice as they've said, however after this go to the back of the fridge and remove the metal insulation cover covering the drain line. You will see a black plastic snake-like shaped section of the drainage system. Remove this section and clean it out with a turkey baster with warm water. This section can get blocked up with either dust and mould or it can have the water freeze up the line causing a blockage. If you suspect that it is the water freezing up do not recover this section of the line with the metal insulated cover.
Posted on May 22, 2011
I have had this problem three times in the past year. Prior to that the unit ran, cooled and defrosted just fine.
I have replaced the fan motor, checked the heater and circuit, cleaned the drain tube and shortened the end of "L" section by 1/8."
The ice that forms in the drain tube extends into the tube by about a 1/2". Once melted, water flow down the tube rapidly.
It is very humid in the NW, but something else seems to have occured with this unit.
Does anone have another idea, I am about ready to go back to a top freezer?
Iced in Olympia
Posted on Feb 01, 2012
I have a GE profile pfcs1njwass fridge making a whistling noise. I read somewhere that the part responsible for this was recalled and ge will replace it free. Does anyone know anything about this.
Sounds like either the expansion orifice or the evaporator fan. Take a mechanic's stethoscope and place the probe on the evaporator tube(s). It will be louder on that if it's the orifice. Sometimes they will make a sound if the system has too much refrigerant charge. Either case unless you are a fridge tech suggest have a tech do this one for you.
Occasionally the evaporators get an ice build-up which can cause strange sounds.
Maybe as a last ditch test before you replace the fridge, try defrosting it overnight.
Jan 16, 2018 | GE Refrigerators
My GE profile performance refrigerator is not as cold as it was
is the evaporator fan working, which normally make the food compartment cool.Are the cooling passages clear, if the fan is not functioning, it will create and ice build up which then needs to be defrosted by shutting it down or with a hair dryer or heat gun.
Jun 08, 2014 | GE Profile PSW26P Stainless Steel Side by...
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
Ge profile fridge will not cool
i would check to make sure you can hear the fan in the freezer you may need to hold in the door switch
Oct 08, 2009 | Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
GE GDS18LBR Bottom Freezer Refrigerator Logo
1,095 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
