Question about Sony KV-32FV1 32" TV
No power One day my Sony TV was working and then all of a sudden it wasnt. Im hoping its a bad power supply. It doesnt turn on at all. No sound, no video. Thanks ahead of time for your help.
  • don meledez Dec 02, 2006
    Thanks Coil, first of all I tried to give you an excellent rating for your advice, but for some reason it isnt working. But anyways, I will try what you advised and get back to you. Again thank you very much.
  • Anonymous Jul 31, 2008
    TV doesn't turn on. The timer light is flashing 4 light and a bad oder is emitting from the back of the TV.
    Please advise, I miss my TV!
    Scholar:
  • 68 Answers
First of all check the power socket is working, by plugging something different in. Do you have fuses in plugs in the USA, like in the UK?-Check this. If you can remove the back and are safe using a voltmeter, then clip the leads where the mains should be inside the set, then plug the mains in. I say `clip' the leads on for safety, so you can keep your hands clear of any exposed voltages on the circuit boards. If you cannot find anywhere to clip to, I would advise soldering a length of insulated wire to attach the meter to, before plugging in the mains. Depending which side of the mains on off switch you are you should see a reading if all is well so far.- Try the on off switch in the set. If this is OK then go a stage further and see if there is any voltage the other side of the mains rectifier. This will be about 150 volts DC in the USA, and about 350 volts where the mains is 240 volts AC. If this is OK then you have a more serious problem, as it most likely in a short circuit line output transistor and will need a service engineer. Check to see while tracing the circiut so far if there is a fuse. Check if you can to see if the `reservoir' capacitor is short circuit or faulty- this is the capacitor just past the rectifier. If you find one thing wrong and can replace it, you will nearly always find there is another component wrong, which caused the replaced component to go wrong also,-so beware! Well good luck.
Posted on Dec 02, 2006
The night before the tv was working fine, but now all of a sudden this morning, when we try to turn the tv on it only plays the sound, and the tv doesnt even light up.
You have a bad inverter board, or bad caps on the power supply. Open the back and look at all the capacitors where the power supply is. If non of them look bulged out, look at the two boards on the left and right of the T.V. Usually only one goes bad. Get a number on the side of the board and look on ebay.
Jun 18, 2011 | Philips Televison & Video
We understand that your problem is: sony kf42sx300u. the tv was working well until yesterday when it appeared to have suddenly gone in to a standby mode...it is constantly in the same mode where the red...
Good day!
You have a better chances if you have failing capacitors on the power supply section.
Follow this procedure on how to replace the capacitors.
  1. Remove the back cover of your TV.
  2. Look for the power supply board.
  3. After that,look for the leak or bulged on the top capacitors.
  4. If you found ,replaced it with the same type,ratings and value.
  5. And finally after you replaced bad capacitors on the board,plug-in your TV and power it ON to test if it is OK.
I hope this solution will be helpful.Thank you and good luck.
May 20, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
My sony tv 19'' suddenly loss power, and when i try to turn it on again, its not working, there is no red light when im trying to turn it on,,
There is problem with the internal power supply of the TV set,if you are technical person check supply fuse in the set if o.k check further by checking voltages in the power supply area or call technical expert to solve the problem.
Jan 16, 2011 | Sony Televison & Video
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
2 blinks, power supply
could be a shortin the power supply
Jan 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
42 plasma panasonic
DUDEEE this exact same problem happened to me!!!! what happened was it was workin fine then it started turning on and off, then now it goes through these weird phases where i cant turn it off using remote or the power button. every button on the side of the tv and the remote doesnt work. so i have to unplug it to turn it off, what a messedup problem!!! im taking my LG 32LB9D to the tv shop tomorrow i hope to get it assest and possibly fix, ill tell u how to solve the problem if my tv is fixed. :)
Oct 19, 2008 | Televison & Video
Sony 36" Trinitron Problem
Good day.
There may have been some problem in the horiontal transistor. Also, Check for the zener diode that controls the supply going to the flyback. It might got busted due to the sudden supply surge.
chris
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-32FV1 32" TV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
