Sir i am having a problem with the error message cd/dvd tray not set correctly
i have try your solution, clenning the roller's, clenning the white marks on the tray, but iam still getting the same error message.
please can you help, this si the second printer i have had the problem with.
Does the machine try to bring the tray in before giving the error or does it display error straight away? Does your CD tray have a clear plastic strip on the leading edge or is the type with a thick black wedge design? Resetting the firmware will have no effect.
You can try and reset the printer if you dont have the tool let me no
I had the same problem and after a few uninstall and re-install, what I did is to pull the printer away from the wall, and voila! it works fine.
What happened is I didn't realize that when it pulls the tray in, it pushes out on the back, and as it was close to the wall it couldn't, so I got the error message.
thanks for the quick reply what tool do i need to reset my printer
