Question about The Singing Machine Singing Machine SME399 Dual Cassette Karaoke System w/AM/FM Radio Boombox
The Singing Machine STVG-700 - CD Loads, but it does not play
All Lights are on the machine. The CD track LED shows - - . The CD loads, but since I opened the back of the machine, the CD stops spinning and the play, program, forward buttons do not work. No action. The radio and TV work for over the air reception.
  • djhappy115 Jan 01, 2009
    I have the same issue. When the cd goes in you can hear it spin for a moment then stop. The track display never changes from "--" but, that's the only thing wrong with it. tape, tv, radio, all work fine. Just the cd player doesn't play. Could the laser be stuck on it's rail maybe?
The Singing Machine STVG-1008 manual
go google --type in-- workshop manual for singer sewing machine model stvg-1008-- and find a page with pdf version down loads
Sep 20, 2015 | Sewing Machines
Instruction booklets on machine
Many of the Singing Machine Karaoke system manuals are available on the company's support site: . The direct link to the STVG-1009 manual is .
I hope this helps.
Mar 24, 2012 | The Singing Machine Singing Machine...
I have a STVG-500 and the CD Player is not working.
Here's a shot in the dark ...try loosening the screws that hold the printed circuit board. It worked for me.
Feb 06, 2012 | The Singing Machine DVD/CDG Karaoke System...
The MTV Singing Machine STVG-700 Manual
I found the telephone number of the company, called and they e-mailed me the owners manual immediatley!! At no charge!
Thanks for trying to help me. I'm sure I will be back as I still have a few more manuals that I need!!
Aug 14, 2009 | Kitchen Appliances - Others
No sound when cd is playing, or on microphone
probably the amp section- I am working on a STVG-700 right now, the audio amp is mounted on the lowest circuit board in the case, includes the power supply except for the transformer. There are fuses mounted on this board, with luck that's all that blew on this. I know this problem is months old, but if you're like me and didn't get it fixed quickly, it's still sitting around somewhere...
May 26, 2009 | The Singing Machine SINGING MACHINE...
The Singing Machine - STVG-1008
sounds like the rom drive needs to be cleaned had a similar problem with a kareokee machine when i was 16 used electrical contact cleaner and some cotton swabs with a cleaning disc and it worked fine
Feb 18, 2009 | The Singing Machine DVD/CDG Karaoke System...
The singing machine stvg-513 cd player wont work
These are a pain in the **** to service. I have a -700 in the shop right now I'm working on, the drive tray was jammed, so I freed it up (trial and error), and while I didn't notice the first time I checked, the flat-film ribbon cable that plugs into the optical (read) head had gotten some of the conductive traces scraped off. I took a cable from a working unit, installed it, tweaked the laser drive just a bit, and now the drive reads track 0 (with the track info). What I haven't yet figured out yet is why none of the CD controls work (>, <, <<, >>, ||, etc.). This isn't terribly advanced service, but it's beyond beginner level.
Dec 21, 2008 | The Singing Machine SINGING MACHINE...
Display keeps saying door
When your site kicked me out and charged me twice, I through the singing machine away! that solved the problem.
Jul 04, 2008 | The Singing Machine SINGING MACHINE...
179 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
