Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I have a frigidaire horizon 2000 washer does not spin
Washer does not spin
  • Anonymous Jan 02, 2009
    Mine doesn't spin on it's own either but putting a screw driver or knife in the locking mechanism allows it to run with the lid open and if I manually start the tub spinning on the slow spin cycle, the machine takes over once the water drains down so far. The machine is 15+ years old so I'm guessing it's a loose belt.
2 Suggested Answers
  • 6277 Answers
SOURCE: Is there a lint filter/catcher
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 26, 2011
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Dont know how to remove cabinet on frigidaire horizon 2000?
to remove the front panel on the washer you have to remove the 2 screws at the bottom of the panel then the panel will drop down out of the slip and groove hooks and you can remove panel
Oct 29, 2013 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire horizon 2000, how do i get to motor?
Check this link which demonstrates fully to get to the motor and remove the drum. Click on ; Drum removal
Jan 11, 2013 | Frigidaire Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin |
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Where can i see the manual for the frigidaire horizon 2000 washer?
go to there web site put in info and the manual should come up then down load it
Apr 28, 2012 | Frigidaire Washing Machines
I have a frigidaire washer, when drum spins it
It is probably the belt.. Replace the belt and that should take care of it..
Have a nice day..
Sep 08, 2009 | Frigidaire CWS3600AS Top Load Washer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Washer won't spin in final spin out
Hello harley1964dm
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
1,291 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
