Question about Kenmore 24 in. 15932 Built-in Dishwasher
Water does not go into dishwasher
Everything is connected correctly, brand new machine
  • 131 Answers
First make sure the water is turned on to the unit(i know but i gotta check)if you'r sure you have water pressure to it.the float may have gotten stuck in the full position.this is located in the tub under a cover,that kinda looks like a small silo.remove the cover & make sure it is at the lower end of its movement.if this does'nt fix the problem i'll need a little more imfo.thanx for using fix-ya.please rate all replys
Posted on Nov 16, 2008
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
Dishwasher is connected but the not working
What is the brand name and model number to your dishwasher? Provide more details please. If you wish to know some details about the repair and disassemble to dishwashers, check this link. Pull up older posts there.
Mar 09, 2013 | Televison & Video
Dishwasher will not fill with water
depending on the make and model of dishwasher the solution can vary. A good guess (assuming the inlet hose is connected and tap is turned on), is the water pressure setting may not be matching with your normal mains pressure. Check installation instructions for setting mains water pressure. Also some dishwashers like Bosch have special inlet hoses which detect water leakage and shut of the water inlet valve. Need to check if your dishwasher has got this feature and need to confirm the hose is correctly fitted.
More importantly check when you turn wash cycle on if you hear click of the inlet valve or not.
Dec 29, 2012 | Dishwashers
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Dishwasher is getting power but will not let me select a cycle
is it brand new? as they sometmes fit **** plugs into where water hoses connect, if water cant pass then machine will not initiate sequence due to the fail safe system to prevent further damage incurrd by not having water flowing thru machine. also water hose could have just become kinked when you located machine under worktop for instance, if it has two water inlet points make sure you connect supply to both as this is required, it doesnt have to be one hot one cold two cold is sufficient and if you only have connections in kitchen for one pipe you can buy a plastic Y junction turning one pipe into two, these are available at most domestic appliance stores for few pound, you will require two more hose though to connect to Y splitter then to machine, failing that if its not new machine its possible the inlet pump is faulty, if pump doesnt start to pump water in the machine will not allow you to access any programs.
May 05, 2012 | Whirlpool Dishwashers
Brand new simpson top load 9.5kg 22S950M will not fill with water - hoses are not kinked and everything connected correctly - any hints?
most likely the rear board, i am a washing machine tech and have had alot of problems with this
Jan 30, 2011 | Washing Machines
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
Our new dishwasher will not pump out water
if you have new disposal too remove the disposal plug so the water can actually leave the machine
Apr 15, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Water is not pumping into dishwasher
When you connected the water line did you remember to turn the water valve on?
Feb 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Bosch dishwasher - Brand new. Will turn on but no water coming into the machine (will not prime). Water connection has been checked.
Check your float assembly. It may be sticking. Check it to make sure the shaft is clean and the float goes up and down.
Dec 21, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
