Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
My dishwasher is actually GSC3400F00BL, GE Nautilus, Ser. No. is TZ607487A. At the end of my tether regarding this evil robotic machine that has found a nice warm home here and refuses to work for its keep. I found a potential solution for its problems in opening up the door and looking for "burnt wires"...they all looked like plain old wires to me. It has two major malfunctions: it fills with water and sits there and does nothing (except tick on to the next cycle) unless i open the door and shut it. Then it will do its washy thing until the next fill. This behavior began with the "short wash" cycle, then cured itself with the normal wash cycle, now has spread there too. It periodically refuses to drain, leaving me with a tubful of gunky water and, at times, water leaking onto the floor. This dishwasher tricked its way into my home by replacing a 20-year-old machine that never gave me a moment's trouble but was rusted throughout its interior. Please help me. I am ready to roll this thing out to the curb. I did have a repairman come and extend the drain hose -- my son has hooked it permanently to a water supply and the hose seemed kinked to the repairman.
Harry, a common drain problem on these GE dishwashers has to do with the piston nut assy. located under the filter grate in back. You can check it out here: http://www.repairclinic.com/0080.asp It's an easy fix, it just unscrews. The other issue sounds like a door switch problem. Remove the inner door and take a look at the door latch and switch for any broken parts. Catriver...post back.
Posted on Nov 26, 2006
Jan 24, 2013 | Dishwashers
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Jun 19, 2011 | GE Nautilus 24" Built-in Dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 15, 2011 | GE Nautilus 24" Built-in Dishwasher
Aug 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
316 people viewed this question
Thank you so much...will buy parts and replace. Could not find anything wrong with the door latch but it felt "mushy" -- noticed that they recommend you purchase the repair manual with this part, it is for earlier models but will get it anyhow. Will post back to let you know (or whine further if still broken).
My problem is exactly like the one mentioned above from Harry-Lou's. I would like to know how to uninstall it if you can not help me fix it. Thanks
