Windows vista winads32.rom error
Hi Everybody,My problem when the windows vista startup this error msg appear everytime '' winads32.rom error ''(It is a Rundll Error)
So... what can I do?!!
  • 1 more comment
  • moselhy Nov 15, 2008
    there is attached photo
  • moselhy Nov 17, 2008
    Anybody there????
    DreadLed, unfortunately... It didn't work !!! :(
    thnx for ur try.
Try to install this windows patch
Posted on Nov 17, 2008
Bootmrg is missing
I suggest that you perform a Startup Repair.
Method 1: Startup Repair
1. Please insert the Windows Vista/7 DVD and reboot the computer.
2. When we are prompted to press a key to boot from the DVD, please press Enter or the space bar.
3. Choose your language settings, and then click Next.
4. Click Repair your computer.
5. Select the operating system you want to repair, and then click Next.
6. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Access the link below for more information about startup repair:
http://windowshelp.microsoft.com/Windows/en-US/help/5c59f8c1-b0d1-4f1a-af55-74f3922f3f351033.mspx
You can also try "Rebuild BCD".
Method 2: Rebuild BCD
1. Put the Windows Vista/7 installation disc in the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. (Click the operating system that you want to repair), and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type bcdboot c:\windows /l en-us, and then press ENTER.
Note: C:\ should be changed to the default partition you installed Windows Vista/7.
http://support.microsoft.com/kb/927392
Oct 03, 2012 | Microsoft Windows 7 Home Premium 64BIT...
I have a CD ROM that is no longer being recognized by my Vista laptop.
Hi, if after a few computer restarts, it still fails to recognize, save your important docs etc, and do a system recovery back before the time you noticed the error.
If after 2/3 attempts still no sign, you are looking at a complete system install!
But first try accessing "Device Manager" clich DVD/CD/Rom Icon. Click Remove.
Restart computer, hopefully this should force a new item found and installing prog sign should appear during startup?
May 26, 2011 | Computers & Internet
Error says this product is not genuine (vista home preium sp1) will not reconize product key
This error msg would appear if your using a counterfeit operating system. To remove this message, you have to activate your windows.
Hope this one helps.
Thanx
Apr 03, 2011 | Dell XPS One Desktop PC RED-20" HD...
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
Forgot my dell inspiron pass word
Dell Inspiron 1000 PC Notebook proplem
Now, if you forget your password, first prepare Windows Vista installation CD, then the computer will enter BIOS first startup Settings for cd-rom start. When the screen, click start presentation by any key cd-rom start system. Then when the interface language appears in the "next", click on the installation interface click "repair the computer ", the "system in the popup window list", click options repair" prompt ".
Aug 13, 2010 | Dell Inspiron 1000 Notebook
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
Microsoft Lifecam-window starts up uopn login
Try to check in the Msconfig, there will be a list of all the Start-Up Apps.
To Do so, Press WinKey+r The Run Dialog will appear write msconfig , Hit Enter.
An other Dialog will appear With many Tabs, you will see a Startup tab. There you will see all the startup applications. Uncheck the Application related to you Cam.
Regards,
Waqar.
Aug 17, 2009 | Microsoft LifeCam VX-3000 Web Camera
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
