Question about Intel Pentium IV M, 3.06 GHz Pentium 4-M (SL77P) Processor
My computer i am sorry, but i told you the wrong thing, i have pc3200 ram, and was worndering if you could tell me what i should upgrade to. i plan on installing 2 1gig sticks if i can, but should it be pc3200 or 2700?
  • 29 Answers
PC3200 is 400Mhz ram, PC2700 is 333Mhz. Check with www.crucial.com and run the system checker to determine which ram is correct for your system. If PC2700 is what you should use you can most likely use PC3200 as it will step down to the speed your computer uses. Crucial, Kingston and other major brands are backwards compatible.
Posted on Feb 12, 2009
    Scholar:
  • 112 Answers
Is the ram that you are putting in the pc3200 or the ram or the ram that was in there the pc3200. If that is what you took out, that is what you should put in. If this is what you plan to put in, you just have to try. Try what you have. It won't hurt it if it isn't compatible. If it doesn't work, 2700 should.
Posted on Nov 16, 2008
Memory wont fit
Take a look at the RAM your trying install and tell me the model number of the ram, if it don't fit you have the wrong ram. You should be using DDR PC2700 RAM for your Memory Upgrade but DDR PC3200 will work as well both are 184-pin DIMM
Dec 24, 2013 | Dell Dimension 2400 PC Desktop
What type of RAM is used, and how to up grade
The type of ram used is PC3200 DDR SDRAM. The maximum ram supported is 2GB
There are 2 slots on the motherboard each supporting 1 x 1GB (gigabyte) each.
If you want to upgrade to the maximum amount of ram then you must buy 2 x 1GB PC3200 DDR SDRAM.
To upgrade the ram take the side panel off the computer and remove the existing ram from the motherboard like in this picture.>>>
All you have to do is remove the ram and insert your new ram. Make sure that you clean the the slots of any dust as the dust can cause boot issues.
Good luck.
Jan 03, 2011 | E-Machines T3120 PC Desktop
I'm looking to upgrade the RAM in my father-in-law's computer (Compaq Presario SR1500NX desktop). All the "see what ram you need" searches on various websites that sell memory indicate PC2700 is...
This is the memory specs for the SR1500.
Presario SR1500NX Memory Specifications Standard Memory 256 MB (removable) Maximum Memory 2 GB Memory Expansion 2 sockets Memory Comments PC2700 DDR SDRAM DIMMs. CPU Type 2.0GHz AMD Sempron 3000+ Model Comments 333MHz FSB, VIA KM400A Chipset.
The PC2700 refers to the RAM speed, so you can use PC3200 which is faster RAM than PC2700, the PC3200 RAM should be more expensive not cheaper unless this supplier has stock he needs to unload.
You will not get any speed performance with the PC3200 RAM because the motherboard cannot make use of this faster RAM.
Dec 03, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
Hi, I have a little problem with the RAM of my Acer Aspire 8600. Probably I am using a wrong RAM module for the upgrade, but I would like to have your opinion. I have instantiated a new module of RAM...
Probably you have used the wrong RAM module in the upgrading. You must be using 1 GB PC2100 RAM instead of PC3200 in order to have a complete 1 GB of RAM.
Nov 09, 2010 | Acer Aspire 8600 PC Desktop
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Tried to add RAM but now computer won't turn on
Didn't we speak online about this a couple of days ago? You can't mix and match RAM. What you added is probably not the right config for that machine. You need to go to this link, plug in your machine information and then REPLACE, NOT ADD TO what you have.
May 26, 2009 | E-Machines eMachines Desktop PC
I want Upgrade my computer memory
You need DDR PC 2700 184pin memory. Your machine will support upto 2g.
You can buy this memory from anywhere at cheap prices.
Hope this helps
Regards
Oct 16, 2008 | Compaq Presario 5000 PC Desktop
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Memory upgrade
you can use any DDR 180pin. But having two RAM of different speeds may not be compatible sometimes, so upgrade it to 1Gb by just using (1) 1Gb pc3200.
May 15, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
